Hello,
I have purchased a pioneer headunit with "Hard wired remote input".
The R32 has two buttons on the dash; AM/FM and Tune
There is a black socket located on the radio loom.
As seen on the picture, the black socket has 2 wires. (i havent traced them back, but i'd assume they would be 1 for each button)
Does anyone know how to make this work with Pioneers Hard wired remote input?
It looks like a need a hard-wired remote control adapter?
Thanks
https://www.sau.com.au/forums/topic/372516-pioneer-hard-wired-remote-input/
According to this;
http://www.pac-audio.com/PACProductData/SWI-PS/1_Instructions/swi-ps_instructions_072309.pdf
The PAC SWI-PS can be used. However, each seperate radio button needs to be wired with resistors in parallel?
http://www.sonicelectronix.com/item_18027_PAC-SWI-PSv1-New-Version-of-SWI-PS.html
Is there a cheaper options available?
I would check the resistance of those. from memory they are 30 and 60 ohms. PAC would do it but I would move the ladder around a bit.
thanks for the input.
Perhaps you could investigate it on your r32 project :P
Any chance you got wiring diagram of the r32? Want to see if there is more than 1 wire coming off the factory radio buttons.
what you *could* do it use the values off the DIY site and mod the switch. that will net a neater solution. in my case the deck I have doesn't support them anyway and I intend to use them for something else.
there are two. a grey one and a org/blk. they both have a common return to the deck.
ah yep.
So;
Grey = Button 1
Org/blk = Button 2
And they share a common return to the deck? The headunit socket only appears to have 2 wires..(no third common return?)
sounds like a good idea. Looks like i'll be pursuing this adventure alone then!
    • FD RX7 I would probably marry if legal R32 GTR is toughest NSX looks like it's made from leftover Prelude and Accord bits
    • When going to a suspension shop should I send them the default nissan settings or just let them do their own thing? I ask this because I have aftermarket rear camber arms (front end is basically stock after I change to those nismo bushes)
    • Ok sounds good, thanks for your help. Hopefully if I end up changing it to the nismo bushes I don't get that veering issue. I don't think there's a point in lubing up these bushes again. Weird that it it makes just as much noise with all the grease inside it versus without grease prior to removal. Bizarre.
    • Yeah, you don't need camber bushes on stock arms to make a car drive straight unless it's got another problem. F'rigsample, slide the thing into a kerb, bend the front subframe mounts a little....subframe is now twisted, shifted or otherwise in the wrong spot...and you need to do funky stuff with the wheel alignment to get it to drive straight. Maybe a little more caster on one side, or a little more camber. FWIW, I can have my camber off side to side by a half a degree or more, and either way, so more one side, or more on the other, and the car doesn't really want to pull to one side. It will definitely ride road camber differently, and want to track uphill (ie, towards the centreline when on the LHS of a normal crowned piece of road, like it should) or want to roll downhill (which it really shouldn't). But on fairly flat road surfaces, like the middle of a 3 or 4 lane motorway, a half a degree either way doesn't make a lot of difference. I sometimes do quite a few miles with my wheel alignment messed up, because I don't always get a chance to set it right again after a serious dismantling, before I have to drive it to work again. Like, a whole week's worth of daily shuffle.
    • To clarify, I meant nismo bushes, not control arms (don't even think that's a thing for my car). So the suspension specialist said, if I buy those nismo bushes which are perfectly centered it will cause my car to veer in one direction. Whereas he said the current offset bushes that I have were put in on purpose to fix that issue. This will be my third wheel alignment if I put these bushes in lol. My chassis is straight, all my rails are clean.
