check the "goods on oils" thread.. its over a 100 pages long but spend a bit of time reading through, improves your knowledge about how oils work.. benefits/disadvantages of types of oil i.e semi synthetic/ fully synthetic etc etc - you'll find your answer in there somewhere. I would go off your dipstick though. start with 4L - turn car on for a few minutes.... let it sit for a bit - check dipstick - keep topping up in small increments until you reach the H level.
Rido sweet will do didn't even no a page like that was around!! I'll jump on now and have a read!! But yeah I'll do that to shouldent be to hard now :) I'll take pics step bye step and post them to
this is where it goes through behind the headlight
You may have done this, but id recommend putting a piece of that plastic loom covering stuff over the lines where they pass here. That braided stuff is actually piss weak in terms of wear, and with movement of the engineetc, it will eat through that line in no time!
I pretty much have mine covered from just after the core to just before the block. Just where you can see the pretty lines it isnt :D
And in a GTR, you cant see squat under the manifold anyway haha.
Ok sweet as will do that then, cheers mate for that!! How to i connect it to the block? Does it just screw In Orr,? I dnt have it yet so i can't look at it a sus it out for my self just got to ask all these stupid questions that will make more sense to me when im holding it probably.
edit: also depending on what Pal has done with his, do not over tighten the oil filter like i did last time.. due to its close proximity to the radiator pipe / fuse box / washer bottle - when you go to do an oil change there is very little room and its quite hard to get leverage without taking the washer bottle out (i broke 3 of those oil filter removal tools, and yes i had to do the screwdriver into the side trick which i thoroughly DO NOT recommend)
dude just get a 3/8 filter claw, a 300mm extension and a ratchet.
Argh ok sweet makes sense now cheers!! Should be wayyy easier thanks
hopefully they give you a small seal where it connects to the block - mine came without one - had to go find a similar ring at the local hardware..
and smokey - i used the filter claw - that just crushed the oil filter more leaving less filter to grab a hold of.
Rido I'll check make sure it has 1!!! Thanks agin
Thanks smokey32 I'll rite that down and get one!! Thanks guys use have helped a shit load appreciate it
i was talking to defari mate.
jheeez ive had some seized ones but never had that happen
    • The door and bonnet gaps look very tight for such cheap models 👍
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
