I have for sale a pair of RE55's used for 1 track day, should be good for several more.
285/30/18's
These retail for over $500ea.
Asking $50ea for these two.
Sydney pick up only, PM me for details.
https://www.sau.com.au/forums/topic/372561-for-sale-2xre55-semis-1828530/
285/30/18's
PM sent. see you at WTAC this fri/sat
