  • Replies 64
You need to check injector PULSE and coil spark first. If you don't have either one, then yes, CAS is most likely
Coil spark by sticking a screw driver or something similar into the coil pack and seeing if it'll spark to the block? Or any other way you recommend?
Injector pulse by pulling one out? Of is it easier to intercept the injector signal and hit it with a multimeter?
ok. pull no1 coilpack out of the cradle, put the spark plug in the bottom of it and make sure its loom is plugged in. earth the threaded section of the spark plug somehow (i rest it against a screwdriver thats sitting firmly against a clean part of the head). pull the cas out, just undo the 3 bolts and carefully remove it, leave it plugged in. turn the ignition on and slowly turn the cas counterclockwise (looking at it from the shaft side), check for spark and listen for the injectors ticking. if you get either your cas is working fine, assuming of course the drive teeth are fine.
Use a jumper lead for the spark plug, much easier. Clamp one end to the motor, and clamp the sparkplug in the other end with the sparkplug plugged into the coil and loom like you normally would.
I can't help but think it's the CAS.
Do I just take it off the base plate (ie, undo the couple of small screws) or do I need to take the base plate off as well?
Yep ubolt the three screws, unclip the wiring and then just pull it out. Mark where the bolts were roughly aligned first to be able to put it back in the same spot.
Once it is out just spin the shaft and see how it feels. Like I said. There should be no resistance what so ever. When they snap the shaft it feels like grinding against sand.
Everything really makes it sound like the CAS so I would suggest doing this first prior to anything else since it is the easiest thing to do.
used to have a vl turbo and when the airflow was on the way out, it puffed alot of fuel and black smoke out the back, very similar to what your talking about, then eventually wouldnt start at all,
have you ruled the airflow out??
I picked up another one, which I can't be certain is working, but it made no difference. Aldo, the voltages seesm close (althought I need to confirm the V when cranking - my memory may not be accurate).
Fairly sure a Skyline will start start even without an AFM signal, just goes into limp mode, so I don't think it would be that.
With stock ECU, yes but don't know about PFC.
Shit I forgot about one small thing. You may have a split or dislodged intercooler pipe.
Check for leaks. AFM swap outs will not diagnose this and it will foul the crap outta your plugs. It will also cause it to run crap and basically every other symptom you described
Should still be able to start the car with throttle open though.
Everything really is pointing to a broken CAS spindle. As the starter motor spins the engine manually during start the ECU receives no signal from the CAS so won't fire any injectors or spark plugs to initiate combustion since it doesn't know the engine is turning over.
actually i can confirm that it would start, mine does without the airflow, just wont rev up pinch.gif ( with standard computer)
Yes, until the spark plugs are fouled....which takes about 5.3 seconds....and, unplugging an AFM is different to having one plugged in with no values being read
Yeah IF he has no spark and no injector pulse, but having a blown cooler pipe or a split one or even a semi large vacuum leak near the plenum will stop if from running. Details are vague over the internet so we don't want to rule out basics until they have been thoroughly checked
I've had a good hunt around for a split in any of the intake. Haven't found anything, but it was probably an 80% look, if that makes sense. It was running at the time, which would no doubt have helped substantially.
I will try and get an injector out, double check the spark and if nothing, pull the CAS off tonight.
I'm trying to be as thorough as possible so people can refer back to this as it seems to be a common problem caused by a number of things. If I can say "these were the EXACT symptoms, this is what I checked, this is what I found, this is how I fixed it," I'm hoping it will help others.
Go to repco or similar and buy a noid light.
This little guy plugs into the injector plug(easily without removing the plenum an fuel rail) and when u crank the noid light should flash. If it doesnt then there is no injector pulse.
Do some basics, check all fuses etc, then if possible borrow a mates CAS to try.
Now the fun starts.
JDMSpares wants a piece of my arse, but has made it abundantly clear they do not wish to use lube. $180+del for a CAS - tell him he's dreaming.
Anyone got a Neo CAS they want to sell to me? The going price looks to be more around $60-$90
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
