  • Replies 64
You need to check injector PULSE and coil spark first. If you don't have either one, then yes, CAS is most likely
Coil spark by sticking a screw driver or something similar into the coil pack and seeing if it'll spark to the block? Or any other way you recommend?
Injector pulse by pulling one out? Of is it easier to intercept the injector signal and hit it with a multimeter?
ok. pull no1 coilpack out of the cradle, put the spark plug in the bottom of it and make sure its loom is plugged in. earth the threaded section of the spark plug somehow (i rest it against a screwdriver thats sitting firmly against a clean part of the head). pull the cas out, just undo the 3 bolts and carefully remove it, leave it plugged in. turn the ignition on and slowly turn the cas counterclockwise (looking at it from the shaft side), check for spark and listen for the injectors ticking. if you get either your cas is working fine, assuming of course the drive teeth are fine.
Use a jumper lead for the spark plug, much easier. Clamp one end to the motor, and clamp the sparkplug in the other end with the sparkplug plugged into the coil and loom like you normally would.
I can't help but think it's the CAS.
Do I just take it off the base plate (ie, undo the couple of small screws) or do I need to take the base plate off as well?
Yep ubolt the three screws, unclip the wiring and then just pull it out. Mark where the bolts were roughly aligned first to be able to put it back in the same spot.
Once it is out just spin the shaft and see how it feels. Like I said. There should be no resistance what so ever. When they snap the shaft it feels like grinding against sand.
Everything really makes it sound like the CAS so I would suggest doing this first prior to anything else since it is the easiest thing to do.
used to have a vl turbo and when the airflow was on the way out, it puffed alot of fuel and black smoke out the back, very similar to what your talking about, then eventually wouldnt start at all,
have you ruled the airflow out??
I picked up another one, which I can't be certain is working, but it made no difference. Aldo, the voltages seesm close (althought I need to confirm the V when cranking - my memory may not be accurate).
Fairly sure a Skyline will start start even without an AFM signal, just goes into limp mode, so I don't think it would be that.
With stock ECU, yes but don't know about PFC.
Shit I forgot about one small thing. You may have a split or dislodged intercooler pipe.
Check for leaks. AFM swap outs will not diagnose this and it will foul the crap outta your plugs. It will also cause it to run crap and basically every other symptom you described
Should still be able to start the car with throttle open though.
Everything really is pointing to a broken CAS spindle. As the starter motor spins the engine manually during start the ECU receives no signal from the CAS so won't fire any injectors or spark plugs to initiate combustion since it doesn't know the engine is turning over.
actually i can confirm that it would start, mine does without the airflow, just wont rev up pinch.gif ( with standard computer)
Yes, until the spark plugs are fouled....which takes about 5.3 seconds....and, unplugging an AFM is different to having one plugged in with no values being read
Yeah IF he has no spark and no injector pulse, but having a blown cooler pipe or a split one or even a semi large vacuum leak near the plenum will stop if from running. Details are vague over the internet so we don't want to rule out basics until they have been thoroughly checked
I've had a good hunt around for a split in any of the intake. Haven't found anything, but it was probably an 80% look, if that makes sense. It was running at the time, which would no doubt have helped substantially.
I will try and get an injector out, double check the spark and if nothing, pull the CAS off tonight.
I'm trying to be as thorough as possible so people can refer back to this as it seems to be a common problem caused by a number of things. If I can say "these were the EXACT symptoms, this is what I checked, this is what I found, this is how I fixed it," I'm hoping it will help others.
Go to repco or similar and buy a noid light.
This little guy plugs into the injector plug(easily without removing the plenum an fuel rail) and when u crank the noid light should flash. If it doesnt then there is no injector pulse.
Do some basics, check all fuses etc, then if possible borrow a mates CAS to try.
Now the fun starts.
JDMSpares wants a piece of my arse, but has made it abundantly clear they do not wish to use lube. $180+del for a CAS - tell him he's dreaming.
Anyone got a Neo CAS they want to sell to me? The going price looks to be more around $60-$90
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
    • The log you did with ECU voltage, can you log the other things too like rpm and oil pressure? Need all that info together to compare easily
