They changed the style a while ago Ive been told, old style had the wipper slot going to the edge of the disk where as the newer ones didnt, like mine.
Are these new ones more efficient at removing built up gasses? Whats the price difference, are these replacing the DBA 4000 or are they just another line.
Just read up on it, no more left and right hand discs, and more off gassing apparently.
Easy on the machining as they dont need to tool up for 2 different sides so they save money on manufacturing, will we see it at the shop, I doubt it.
Extra off gassing is good if its needed I suppose.
Yes, new things scare me......................
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
