ATM i have an oil filter relocation kit and as it's auto, have a larger size cooler in front of the A/C rad. There is not much room left to put an oil cooler. What do you suggest?
JJ have some good looking kits, but where do I put the cooler.
I am not a purist where the Stag is concerned. I like mine to be mine.
As I have an FFP, There is plenty of room under the strut brace. I have thought about it but would need a bonnet scoop. A la bricks.It would be different, not purist, The air in would be cool and not hinder the frontal radiator system. The exiting air would be hottish? How would the coil paks feel? I currently do not have a cover.
What do you have????????????????
https://www.sau.com.au/forums/topic/372610-wher-to-put-it/
Driver side in front/under washer bottle(the future house of mine),just make some vents at the back(in front of the wheel)as I prepared today
https://www.sau.com.au/forums/topic/372610-wher-to-put-it/#findComment-5942402
i run coolers on both sides,
Trans on right along with oil filters ,trans & engine oil,
on left i run engine oil & Power steering,,
i cut all slots on right hand side out,
coilpack heat is better with COVER OFF,centre cover that is, S2 had silly neo cover to cook coilpacks as well.
with your OIL LINES run larger size hose as you want Volume of oil to go to filter & cooler.
good luck Hugh
cheer`s Chuckie.
https://www.sau.com.au/forums/topic/372610-wher-to-put-it/#findComment-5943870
