R32 Gtst Brakes
hey guys
well i am nearly shore that i dont have the stock r32gtst brakes on my car
a mechanic has told me they are gtr r32 brakes....
some guys on the forum i have met up wit me have told me r33gtst brakes
well to the point i am up for new rotors and i have seen a guy selling dba rotors on here for cheap soe has gave me the price for
r32 gtst rotors but will this fit since i have these brakes on my car
this might be a stupid question but if anyone noes it would be a big help for me
thanks
hey guys
thanks
Pics?
well boostn imports has contacked me after i asked if they would fit ( the guy who sells the dba rotors) and he says they wiill fit even if they are upgraded rotors
i am guess since he seels alot of parts on here he will no
R32GTSt are 280mm rotors.
R33gtst and R32GTR are 296mm rotors (IIRC 32GTR is 2mm thicker).
If you try to run 280mm rotors with calipers meant for 296mm, you will have a bunch of pad hanging over the edge.
If you try to run 296mm rotors with calipers meant for 280mm, you won't be able to bolt the caliper back up.
  • 4 years later...
Bumping and old thread, can anyone tell me what brake callipers are in the first photo, supposedly the second photo is r33 gtst ones. Car is a 92 r32 gtst.
Thinking of buying the upgraded gtr gktech rotors with adapters because they come in similar pricing as some good DBA rotors..opinions on pads?
Edit: measured the rotors on the car, 280mm which means they are 32 gtst? And my spares are 296mm which means 33 gtst or 32 gtr. The front gktech gear doesn't fit with r33 gtst rotors though because if the rotor width difference... ( http://www.gktech.com/index.php/z32-r32-s14-s15-caliper-bracket-to-suit-324mm-r33-gtr-rotor-1.html ) would you buy the gk gear, or put 33s on there? Either way I need front rotors and I'm not sure what's better
Edited by Walfers
The calipers with Nissan written on them are 4 piston Sumitomo calipers, the R32/R33 Turbo coupe models use them as do R32 GTR models.
Edited by GTRPSI
This stuff is really not that hard.
R32 GTSt calipers are easy to space out to the 324mm rotor that many want to space out to. The dogbone adapters for that are a good design, everything goes together well.
R32 GTSt calipers are impossible to space out to 296mm, so you can never fit them onto R33 rotors. Nor would you bother when you can just buy some R33 calipers to go with 296mm rotors.
R33 GTST calipers can be spaced out to sit on a 324mm rotor, but the dogbone design is not excellent and you will probably need to grind some caliper material. (To be fair, you might even need to do that when slapping 32 calipers onto 324mm rotors also, because the calipers that suit smaller diameter rotors don't necessarily have the right 'curve' to fit onto bigger rotors.)
Nobody will be able to tell you which calipers are in either of your photos, because it is the length of the legs that is the main difference between them.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
