*** Performane Imports Feature Car - R33 Gtst, Full Gtr Body Conversion, 338 Rwkw Forged Rb26/30 ***
Complete bare metal paint in Winning Blue, all genuine Nissan GTR panels, skirts, bars & wing etc.
Approx 6000km since build, 94000km on original car
18 x 10 +14 Sparco Viper R wheels
Ferodo DS2500 brake pads
Kumho KU31 tyres, 275 35 18 rear, 245 40 18 front
Tein Australian spec adjustable coilovers
Front & rear strut braces
Sparco Torino 2 front seats, rear seat trimmed in matching Sparco material,
Innovate wideband A/F meter
Alpine stereo,
RB26/30 fully balanced forged engine making 338rwkw/455rwhp on BP ultimate 17psi.
Tuned by GT Auto Garage
Ported head with uprated valve springs
Argo I-beam rods
ACL race series bearings
Nitrided crank
Torque plate bored
CP 8.5:1 forged pistons
ARP2000 head studs
ARP2000 main studs
ARP2000 rod bolts
7L baffled sump
N1 water pump
ATI balancer
NPC twin plate clutch
Autronic SM4
Bosch 044 fuel pump
Turbosmart FPR800
Turbosmart BOV plumbed back
700cc injectors
Custom low mounted manifold, GT35/40 turbo with .82 exhaust housing
Turbosmart 48mm Pro Gate
9" K&N pod filter
All alloy intercooler plumbing & intake
3" Mandrel exhaust with Stainless mufflers
Rarely driven, car is in immaculate condition.
Located Brisbane QLD
Featured in Performance Imports magazine issue 131. Full reciepts & vehicle details including build photos available. This car requires an experienced driver, inspection will not dissapoint. no joy riders.
Ph. 0418719626
$35,000
Edited by Godzilla33
i wasn't having a go at you mate... i opened the thread as a potential buyer but if you want to be a dick about it then goodluck with your sale
fyi - i like the idea of having abs for when one of your "real drivers" pulls out in front of me and i nearly slam into them.
oh, but i am sure you have that split second time to pump your brakes in the heat of the moment.
go tell lamborghini that "real drivers" don't need abs and see what they say
Edited by Mr. Pav
Thanks guys
Curb bashed rims, I cant believe your worried about driving a car back that you would have just paid good money for!! :-)Cheap flights up, just need to see if you could get back to Newcastle without racking up some speeding fines.....
I've seen this car..its like brand new and well built not like most others you see...Perfect street weapon ie: stealth mods,Big performance and reliablity!
No way you could build one like this for the asking price..bargain i say!
If only i had the money...:(
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
