Ok so I'm pretty sure I know the answer to this
I went and test drove a cheap r34 at a dealership today $15900 was the price but I though what the hey it might need a small amount of work but for the price I'd check it out
The car started up fine no smoke
Was idling at 2000rpm till it warmed up then settled down to 950rpm
Oil pressure and temperature were normal
BUT the check engine light did not turn off it stated on the entire test drive the car also didn't feel very like I expected I've owned and r33 before and the r33 felt like it had way more power
The dealer obviously tried to hide this by saying that when the car was picked up the driver filled the car with 91octane and that was the reason for the check engine light and lack of power
Could this be the case or is it more likely the engine is f**ked?
https://www.sau.com.au/forums/topic/372624-91-octane-in-an-r34-gt-t/
Yeah but had an s13 with a hole in the fuel tank I got it fixed and the stupid mechanic filled it up with 91 octane the car shook and spluttered an no check engine light
This car idled very very steady but just had no power and the check engine light worried me doesn't the light refer to an actually problem with the engine not the fuel supply?
if the knock sensors are registering a high amount of knock then it may come on. easiest thing to do would be to check the fault codes, or have them fill it with premium fuel and reset the ecu and see what that does. generally the CEL refers to an electrical issue (or damaged sensor). won't refer to the physical condition of the engine in 99% of cases
i got some better advice, find another car there is to many of these car on the market to even think of buying one with problems is just crazy remember it's a buyers market.
goodluck with your car hunting.
Yeah I ended up settling for a nice s2 r33 for $9500
It's stock as even has the airbox and SMIC so I'll save the excitement of owning an r34 for another 2-3years
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
