  • Replies 61
Wow at the thread revival.
Since this thread i really did change my plans
NOW RB25DET NEO
Mild head porting
Heavy duty valve springs
Factory cams (keeping VCT)
Factory valves and guides
Garage 7 steam pipe manifold
GTX3076 w/ .63 rear housing
Ill be happy with 320-350 kW @ the hubs which this will shit out on E85.
Now this is an awesome setup, so much fun!!!
Mine with poncams -
Ians without poncams -
Type A or B poncams?
Both still using VCT?
What are the differences between your setups.
Im retaining the factory plenum for the time being.
Type B poncams with HKS exhaust cam gear and Performance springs and retainers.... 260's with 9.15 lift i believe!
The ethanol content mine was on to run the 360kw was E70 as that is the current E-Flex percentage, my car is setup to run full flex....
They are the same because i copied his :P
GT3037-56T with 6Boost manifolds, .82 rear housings, Tial 44mm MV-R gates.
Ians runs a side pipe, mine runs a full exhaust.... His spools quicker than mine as i think my exhaust is restrictive.
They both run Plazmaman plenums etc...
If there is anything else, just ask as i am happy to help! Simon-S14 ran a similar setup too and made similar results so its a proven performer setup :D
yep
but there is def a difference when tuning on e70 vs e85
my brothers car made 420kw on with 65% ethanol in the tank
the tuner told us to take the car back... put it around and come back with 85% ethanol (once all the old unleaded is gone through the system) so he can wind up the boost... expecting to make 450-460 on full strength e85
Doesnt matter, it shows the NEO + 3076 combo done right is a win everytime :woot:
Umair - The car is tuned to the current fuel available, i could have tuned on drum E85 and made a tad more (although the turbo was the limiting factor i believe) but it was tuned on E-Flex which is 70%, there is compensation in for higher E content, but it made the power on the pump stuff!
Ahh so identical setups. Nice.
How come hes using factory cams?
Do you find hes got slightly better mid range with stock cams on his?
Yes .63 rear is more restrictive, but is much better for response.
Yeah pretty much the same thing, i have a few slight improvements etc but pretty close!
It was to be an unopened engine with bolt ons and it made impressive power so i guess he didnt see the need.
If we had identical exhausts we could overlay the graphs and get a comparison, but mine behaves differently and comes on later so i cant give you an accurate answer, the mid range on mine is awesome and when it comes on boost its pretty aggressive, and that is on low boost so far, am yet to get it on high boost with the E70
How much response do you need? I think ians is around 3700-3800 and mine is around 3900..... There is the twin scroll result from Owen in the RB25 thread that is pulling full boost way earlier so you could look at that too!
yep
Yeah... nah, the power difference between E70 and E85 would be the best part of zero
I think this was raised in the Guilt_Toy thread a while back and was mentioned that the difference was minimal.... Depends if we are comparing an E-Flex to a Sucrogen or something like that? Maybe its not the percentage but more the fuel itself? Either way, my result was on E70 and was awesome! I was over the moon and will be for a long time :D
yeh same issue with me... im not gonna both driving 40mins to get full strength e85 so mine will primarily run on the Caltex eflex as well
but I doing the fuel flex tune on full strengh e85 is best because that way you have complete range of different proportions on e85 strength in your tune
its going to be boost which will make more power but we will only wind up on full strength because it will be safer to do so
420kw on a stock motor... and we've been flogging the crap out of it so far!
yep im comparing eflex (70% most of the time) to united (85%)
its interesting stuff
i've hooked up my laptop to the Haltech and watch the fuel composition go up and down.... was sitting at 68% last time i filled up with caltex eflex
The 3076 wont make much more power as the boost was already trailing off on my car indicating the turbo was out of puff..... So it may be relevant to a different turbo but not so much the ones being discussed! In saying that the GTX probably has a bit more than mine does, so who knows....
mate does your flex setup varying the boost depending on proportion of e85 in the tank?
Edited by usmair
No, below 60% i run low boost, above that i press high boost.... Only picked up the car Monday so i am yet to try high boost.... Am up to E54 or something....
    • You’ll want to have the block drilled and tapped to suit 1/2in head studs and the head for the same. How much power do you intend to make?
    • Sorry for resurrecting an oldish thread Not much has happened in the past year since the last update. The car did another 1000 miles or so and failed the MOT for the first time in October (failed on tyres which had been advised for a couple of years) In October the car got put up for sale and was removed in November due to no interest, being so close to christmas it was to be expected. The roads were dry in February so I decided to tax it early and get the new tyres fitted.   Fast forward to April, I got someone in to give the car a good clean after sitting for the winter.                                 The car got re-advertised and today (Saturday 3rd May) the car sold. The new owner is planning a GTR conversion at some point and a respray in the same pearl white. It's bitter sweet, it's a shame to have the car sit there for half the year and then only do 1000 miles. The kids are growing too quick and space in the back is getting limited. It's been a great 6.5 years of ownership
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
