No, below 60% i run low boost, above that i press high boost.... Only picked up the car Monday so i am yet to try high boost.... Am up to E54 or something....
aahh
my boost is going to be controlled through the Haltech solenoid so its going to adjust it accordingly...
really interested to see when its all finished
  • Replies 61
Would still very much like to see some MPHs out of these cars to see where it all sits, to date there isn't for any of them.
Thats because MPH readings are over in 13 seconds... Dragging the average uleh commodore isn't that appealing. Sprinting is where its at.
I'll do the 1/4 mile one day, but i actually have to get my car back together before i can do any event lol.
:yes:
However your approach to corners is a little different then most :P
Nothing wrong with that. As long as it has corners you can take at speed thats all that counts. :P Unlike events like power cruise :ph34r:
With "360rwkw" it should be well and truly over in 11 :)
But then you did say "at the hubs", so at least you get that it's not really "rwkw" :thumbsup:
We like to use a hub dyno because nothing such as tyre pressure, tyre grip, wheels size, wheel width, tyre temperature etc etc can effect the outcome. Its always the same, no ifs or butts.
If you use Temperature correction then the results are as real as they come. YES there is a difference between power at the hubs and power at the wheels. Personally i dont care if its making less than XX kW @ the wheels.
Personally i want the most accurate figure possible so the tuner can do his job even better. The torque accuracy of the hub dyno is second to none. It calculates diff ratio and will give you the actual torque created at the flywheel by the engine.
MPH times really aren't an accurate way of proving or dis proving a car/engine setup. Far too many variables. Different drivers, different cars, different suspension setups, different tyres, reaction times the list goes on.
Just because a car makes a gazillion kW on a dyno doesn't make it the be all and end all. But on the flip side a car that only produces a 'low' power output doesn't make it a car that can't perform and put serious numbers down.
MPH never lies, the slight variables only ever have a 1-2mph effect at best as we are not talking tightly set-up 9 second cars where things like tyre size will actually make a difference to peak RPM(limiter avoiding) and so on. MPH has called the bluff many times over the years on here and will no doubt continue to do so for many years to come :)
Group dyno days also work in the same fashion (and the same excuses for not going come up) - It's always a laugh to see a car having a "bad" day when its 50rwkw down for "no apparent reason"... Or should I say, suddenly making realistic figures.
I've also seen @ some dyno days, the operator playing with the old temp correction trick for their own cars so they make more than anyone else's :)
Either way I wasn't having a go at you - you say it's @ the hubs and not "rwkw" like other claim - that is a damn good thing.
It sets realistic expectations for other users so they suddenly don't come along thinking you can make XXX"rwkw" from a set-up that simply put, will never make that.
Then we end up with threads here "Why am I down on power", "Is my tune shit" - list goes on. Other users face palm and then such threads end up a lot of time going nowhere.
Mines rwkw :D
you done?
I'll be done, when you are done claming rwkw** for hub results and misleading users.
(**as proven to be inaccurate to the tune of 40-60kw, by other users who've done back to back tests).
That's cause he sets it up right. He even have you pointers to do the same in a thread a lil while back :thumbsup:
Claims? Other users have proven it with evidence! That is not a claim.
For the love of god Ash, don't go onto the pommie site. Had one guy the other day '550-600 HP "at the fly" when he hadn't even stuck it on a dyno.
You will have a heart attack and die I'm sure of it.
All my tunes have been done in the same set up mode, ramp rate and temp probe on as what Trentuses, sorry to burst your bubble.
One time it was tuned and made over 400kw however that was due to the temp probe not beingon thanks to the last user in the dyno taking it off
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
