Before some pretentious ass tells me to buy rims that fit with the right offest, they're sweet jap rims at a good price and unfortunately i don't earn enough to buy new.
Anyway I'm getting some rims for my skyline, want some pro fitment for it and they are;
Front 17x8 +40 215/40 would like them flush
Rear 17x9 +40 215/40 want them sitting out of the guards a bit
Cheers mate
Ive got +40 up front on my R33 GTST with 235 tyres and a 5mm spacer. They do NOT sit flush and there really is not more thread to hold onto.
I don't trust those bolt on spacers. Id get longer studs fitted and a proper spacer made to suit your car.
I can't stand running spacers. I hate it, I don't trust it but unfortunately I don't have the $ to get wheels to fit so I just left them on the car.
I know you said it in your first line but honestly man just wait for the right set of wheel to show up. You can get defected for running spacers and depending how big they are you aren't going to have much thread to grab onto.
Edited by SargeRX8
how far in do they sit? i'm getting bolt on spacers
Far enough in you can't see them at all when looking from the ass end of the car.
30mm spacer lol. I've got 5mm(pass brakes by 2mm) and I'm hating it. I get what, 5 turns onto the lug.
The spacers he'd be looking at, would have studs in them and nuts to bolt them on to the cars hub. Spidertrax_whs_011.jpg
You don't want massive long studs with 30mm slip on style spacers; it's too much load on the studs, flexing them. 10-15mm slip ons would be about the maximum IMO. A bolt on spacer is a much better alternative; but only hubcentric ones.
Sarge; Not looking to insult or offend you; but 5 threads is nowhere near enough to hold a wheel on; you'll just pull the thread out of the nuts, and chuck a wheel.
As a fitter, I have always used 1.5 times the diameter of the thread as an acceptable amount of thread engagement. So on a M12 x 1.25 wheel stud; 18mm is optimum. At least aim for 12-15mm.
Please go to Repco and buy yourself some longer wheel studs before something terrible happens. It'll cost you $60 and an afternoon on the driveway.
25mm front 30mm rear bolt on spacers, you should be able to find a set of ford Pre AU to AU adapters on the cheap as theyre very common.
having said that, im running 19x10 in a +22, with an additional 35mm bolt on to get the look i want on the rear, with offset less is definitely more ;)
Cheers mate
it will never happen dont bother.
Minimum tyre width for 9in is 235.
based on what ?
for the front to sit "close" to flush you'll need about 30mm spacers
dont encourage such stupid ideas billy!
bloke needs to save up and buy decent size wheels they are freakin honda spec rims.
im running 225 on my 9 inch. and it looks fat.
and you only need 20 or 25 to sit fluch as ive got 25 and they sit abit past the guards, i have also just ordered 55mm :D
just make sure you roll the guards well so no scrubbage occurs.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
