funky you sat GAMSAT? are you studying med?
GAMSAT = graduate australian medical schools admissions test
basically 9am-5pm of breaking the nuts with freaky-ass questions and stuff
not good, but you have to get a good score if you want to study medicine or dentistry...
https://www.sau.com.au/forums/topic/37265-gamsat/#findComment-746808
yeah I know what gamsat is. Its not compulsory to med in NSW, but if you wanna do dentisty in NSW or Med in other states you have to do it. I got accepted into med, but I turned it down n did M Biomedical Engineering / B Computer Engineering instead.
https://www.sau.com.au/forums/topic/37265-gamsat/#findComment-746842
yeah got your pm about bar. have decided to go 3" exhaust before front bar so will have to wait unfortunately ;)
GAMSAT was a bitch yet again. tough stuff if you ask me. how did you find it? how is third year treating you? let me know if you want my help or any work i can give you etc.
waz.
https://www.sau.com.au/forums/topic/37265-gamsat/#findComment-754101
you can order practise tests when you register for the test (www.acer.edu.au) but otherwise no. there is a brochure with the format ofthe test etc. but its designed to test your way of thinkign and interpreting data rather than general knowledge. thus its hard to study for.
https://www.sau.com.au/forums/topic/37265-gamsat/#findComment-755719
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
    • Yeah car has 110 on the clock. That said the front turbo (that exploded) doesn't seem to be the original, it has a S1 part number but the car is a series 3. Yep, in the cat is where I first found the turbine wheel pieces - a couple decent sized ones, then a whole lot of fragments.  I agree, probably makes sense to upgrade parts that are being replaced. Things like rods would be 'nice' but realistically it seems unlikely they would need replacing. I was hoping that it was a case that they generally f**k up the valves but not the bore, or vice versa. Is it generally the scour damage rather than ceramic bits getting mashed into the piston tops / valves? I tried a search but couldn't find any threads with pics from the guts of a motor that's had this happen.
    • Front seats now in, fixing a little rust then front doors sealed up again finished. had to install a fire extinguisher within arms distance of drivers seat for hill climb regulations. little bit of good old silo diff action lol IMG_9146.mov
    • If I had logged into the forum and saw that I would have  Missed out again.
