23 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
That would make sense, but a search around online says the figure varies considerably depending on the car (obviously).
But AWD autos have the most drivetrain loss, and figures I saw thrown around online were between 25-35% loss. If this figure is constant, which would make sense, maybe it's 25-35% off the stock figure?
  • Replies 211
exactly...I was gonna say so my car must be 370kw at the flywheel!!
AFAIK the loss is a constant figure, not a % which increases with power!
Correct it's a constant. If initial loss is say 35kw thats it. It doesn't multiply the loss as it makes more power. The amount lost can also vary depending what gear the car is tested in. So it's a highly variable figure and one I don't usually worry about.
Edited by slippylotion
Hey guys.........excuse me.........,m35 owners???
Less talk about killa wasps more about cruising, this isn't another" I can't tune my 35 because turbo is about to blow up" thread.
Back on topic please
Ok, lets resume our regularly scheduled program.
Are the C34s going to turn up or have they all rusted apart? :nyaanyaa:
Yesterday I picked up ours from the "Ding Shop"...now looking very "bling"
All the "cuts & bruises" have been repaired...not sure why the Japs put foam under the mirrors ?
....sure doesn't help long term preservation. Did they do it to the M35's ?
"them OLD folks"
Too early to organise a northern meeting point for a convoy to the dirty south? Parrofield airport carwash anyone?
Happy to meet at the carwash first :yes:
"the OLD peeps"
yep well new bubs is hear "has been for two weeks" so we will all be there, should have brake up grade and sway bars done by then if i get off my butt , maybe even new turbo upgrade :ph34r::cool:
Congrats mate, Boy or Girl? Its great to see the Stag families growing every cruise :thumbsup:
Must of been the year for bubs
satachi >>> olds>>>
im up for a carwash convoy at parafield.. when we thinking.. 9:00 7 leave 9;15 to get there by 10?
let me know
I'm not sure where the meet point is exactly yet...then we can work out how much time we need to get there
but 9am is OK with us ???....over to you Satachi ??
OLD Mark
If the meeting point is the same as the last cruise Robbie organised, leaving the wash at 9:15 should get us there in time.
Robbie can ya pass on the plan of the car wash meeting point to the northern leggys for us? Cheers
Edited by SatchiThaStagea
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
