aaron + scotty
I want to go split (although im not a fan) so i can do a fully sick westside screamer pipe setup...
scotty - I did notice the cutouts in the turbo outlet, I was considering making the bellmouth then kinda retro fitting a 2inch tube through the wall of the bellmouth that sits just infront of the internal gate... more of a diversion/guide for the air in to atmosphere (screamer), kind of a hybrid screamer? lol
Pics up soon of the bellmouth. but if you want to see my fab work just add my on facebook i put most of my pics on there, its under *gston deuced bear* minus the stars.
or you could suss out the fabrication thread on ns.com which i usually update
http://nissansilvia.com/forums/index.php?showtopic=489295&st=0&fcat=
  • Replies 109
aaron + scotty
Cool but what is this Facebook you speak of?
Just do a Garrett setup like mine, I miss the screamer. :ninja:
Should be there as well.
Cam, do you want me to bring the Wiring Diagram books along? Both books (NM35 and PM35)? Happy for you to borrow them for a while...
Jethro - i'll bring the foglight switch and relay with me in case you do show!!!
Edited by prince_skyline
I should be able to come be will be late :/
Will give u a call and see where u guys r at around 11ish as ill be in Springvale
thats cool. bring the kiddies!
it says that departure will be at 11:15.. i dont think everyone will be there before then.
remember to the guys that want the language conversion done can you all let me know
    • Hey guys, I have dipped my toes into the pool of skylines finally and figured I would get amongst the forums and make an introduction post! My name is Callum, I'm from the north side of Sydney, and I am now 6 months into owning my 1992 R32 GTS-T (already having half of that time off the road in true nissan fashion). It is originally an AH3 car but at some stage of its life it has been resprayed in and out in TH1 with (in the sellers words) extra purple, parked next to an actual TH1 car it is a fair bit lighter in colour. It has also had the original RB20 swapped out for an RB25DET NEO which I presume to be out of a Stagea going off the AWD sump that has been sealed up. I won't go super into detail with mods as I want to create a build thread post soon. Unfortunately the car seems to have had a hard life as many of these have being previously a cheap sub 10k car, and I have barely any history on it so if anyone happens to recognise the car or thinks they may have any history I would LOVE to hear it as I am a bit of a nerd when it comes to car history, the seller had it roughly since 2020 I believe and was from Parramatta area if that helps. Look forward to being a part of the community, I have been to 2 SAUNSW events already (one being in 2022 prior to ownership, and once more a few weekends ago) so you could say I am not brand new to it but can definitely be more involved via the forums! (side note: I am pretty new to forums and struggled to attach pictures of the car, is there an easier method than having to have the pictures on facebook and copying the link from there? would love to know for future reference cheers!)
    • I have GT2860R. I'm not sure if they are -5 or -7. Do you know? These are the exact ones.  https://www.enjukuracing.com/products/garrett-rb26dett-gruppe-n-turbo-upgrade.html?srsltid=AfmBOopSCzHaDtf7nggL6R8KrD8RJP4wxBJitmkRmswmv2SaEbAVcxTe And to be honest, i think the car was the most enjoyable to drive on the streets when it was 280hp (205kw). I could enjoy all the revs to redline i wouldn't be going crazy fast, but just fast enough to know that you are working the car.
    • If i used a cooling system pressure tester, would it show me a leak with the head gasket? Ive used one before to chase down a leaking coolant hose. Not sure if this will work on the oil-cooler warmer.
    • Hi all,   suspect this is a common problem. I think I missed 4th gear a bit when I shifted down from 5th. Now it grinds into 4th with the downshift. Is it the sychro and what do I need to replace when I open the gear box up?    added a photo of my new titanium intake I just installed and built. 👍💪
