VN Group A VN Commodore mock up (built by NSV - Northern Special Vehicles with build plate) --- looks exactly like the real thing -- even has the right badges and an identical interior.
Some original parts: Bucket Seats, Rims, Zorst ....worth $$$$$ for collectors,
Has tight suspension
150000km
mechanically sound although slight wobble in steering wheel while breaking due brakes needing to be remachined.
S1 V6 buic motor
automatic
No registration
Currently sitting on the side of the road 50km from mackay where i was pulled over LOL and had my number plates taken by the police, needs to be towed (or sneakily driven back to mackay heheheheee).
Located in Mackay
would suit a buyer looking for a car to throw in a new motor and driveline and apply a coat of paint (show car sort of thing) it could also make a mechanically sound paddock bash car or a car for spare parts if you own an original group a (of which there were only 300 made)
It has been nick named Tugga - the toss mobile (mainly because it gets driven like there is a wanker behind the wheel LOL and is the sort of car that bogan testosterone fueled hoon die hard mulleted holden fans that are walking talking penis's would drive)...... It corners rather well with very little body roll due to suspension and sway bars .... i used to use it to thrash through the adel hills - holding it in second gear with the air filter and exhaust disconnected... pulls as hard as a V8 modern commodore with those modifications LOL especially when it hits 4300 rpm to 6000rpm.... The car also likes to rev - i think that the motor has been built by the NSV people although not sure... any how i have never had an issue with it and i used to hold it close to redline.... the motor has never missed a beat and starts first time instantly every time....
you can not go wrong for around $700 ono......
If in the odd chance that Xzibit you do read this and are still involved in the pimp my ride game LOL (may be wishful thinking) this would be a perfect car to tweak (ie huge donk of a motor needed ie 454Ci etc and driveline (powerglide or 6 speed manual) due to it being a copy of a rare model....
$700 ono will accept all reasonable offers...
Mackay QLD
Chris
0466915251
Got to love your determination Chris.
No airfilter and no exhaust disconnected.
Sweet man. I bet that would have been a treat.
Id try wacking a sign on the window 500 bucks drive away and a local might take it.
Good luck my friend.
Cheers Swoopdown, it did run quite well with 10 min worth of mods (35% more power) as far as a boat - commodore will....
Was quite fast for that type of car around the hills considering its weight and its brakes... did have good suspension however...
As for Benjamen74...thank you.... you are a very positive minded champ...... I have had about 6 people intrested since i put it on the street with a for sale sign... defenitely sold... Sold within 2 hours...... (as it has several thousand worth of parts on it due to the fact that there were only 300 originals made.....) ..
mods... once again please keep these negative wank stains from hating up my for sale threads.... i have no time at all for these hate riddled manequins... surely you should be banning them.... thank you... :-)
so many haters and flamers on these forums...... :-(
Edited by macdoodle69
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
