Anyone Here In Vic Have Big Brakes On Their R33 Gtr?
I am looking to buy some big brakes for my R33 GTR, but first need to know if they are going to fit over my wheels (18x10.5 Wedsport SA90's, not sure on the offset)
If anyone here in VIC has AP Racing brakes, 6 piston with 355mm rotor can you please let me know if you are willing to let me trial fit one wheel on your car?
I dont mind travelling.
Cheers :)
Cheers :)
mate pm xrotor
he has ap's on his 33. he had work or weds (not sure) but they didnt fit.
355 won't be a problem with those wheels. I have the same ones (so im assuming you own a purple R33 as well? Leewahs old car?).
I have a 356 D2 kit waiting to go on for testing in the next month or so and from the initial look they were going to be fine.
Yep, thats me, I own Daves old car (Leewah). I bought it earlier this year at a price that couldnt be refused :)
Do you have AP Racing brakes on your car now?
Actually i'll be @ Racepace Tues or Wed, and my wheels are there. I'll chuck them onto a car with brakes (always one there) and let you know.
You sure that you have the same wheels in the same offset as me?
I have been told that the ones I have are one of the only sets in the country.
If they are the same, then that would be awesome :)
18x10.5 - i can assure you they are the same as Aaron & I were looking for another set for the better part of 8 months.
I don't have the D2s on yet, but there is always one GTR with a 356mm kit @ Racepace so it won't be a problem.
Will let you know. Probably gonna be Wed as im a bit crook atm.
Dont have a lot of clearance with the standard Brembos. Maybe 15mm??
I dont like your chances then, still worth a try :thumbsup: Only one way to know for sure :D
Alternative is spacers, but spacers on a GTR :s?
15mm? :ermm:
What offset are yours?
Been a while since I've looked @ mine but we were almost positive it would be all fine when we were looking a couple months ago as intent was always to upgrade brakes etc.
It's not the end of the world if they don't, plenty of wheel choices out there that will accommodate for bigger brakes. I'd rather have the braking performance at the sacrifice of having 'wheels that make the car'.....
Just my 2c.....
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
