GCG Hi-flow turbo with VG30 rear housing, good condition, suit rb25. Also comes with a standard rear housing $1000
APEXI Boost control kit (PFC add on) $350
Datalogit with cables and software $350
Nismo twin plate clutch $700
greddy copy intake manifold, polished $200
Clear timing belt cover $50
Adjustable cam gear $80
(new) adjustable castor arms $150
(new) sub frame alignment kit (pineapples) $60
(new) heavy duty polyurethane gearbox mount $60
(new) RB30 oil pump drive collar $100
Also have a few standard parts
Sway bars
S2 front bar with fog lights
standard side skirts and rear wing
I/C cross over pipe
Make an offer.
All parts located the far south coast NSW .
I will post at buyers expense.
any info on the specs of the highflow? cheers
GCG link below.
My link
These are the ducks guts of Hi-flows, ball bearing, 100% bolt on.
and with the VG30 rear housing it's capable of 260+ rwkw.
Have a search around the forum, there are plenty of discussions about them.
Edited by Hootchy
I bought the turbo 2nd hand with about 10,000k's. I had it on the car for about 2 years and did less than 15,000k's.
It has minimal shaft play.
Here's some pics of other parts post-24599-0-03597800-1312978745_thumb.jpgpost-24599-0-03715800-1312978758_thumb.jpg
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
