Bunch of parts for sale. Reasonable offers considered.
RB26 RWD Sump - High Capacity
Modified rb26 sump, diff casing etc removed and complete new winged 'bulge'. Sits dead level with the x-member so there are none of the usual ground clearance issues with most rb26 sump extensions.
Includes tomei baffle.
Milled dead flat so there are no sealing issues.
$750
Bride Recliner
Average condition, one tear on the drivers bolster which has been patched. Includes a Bride seat rail to suit HR31
$400 with rail or $300 seat only
RB26 Engine Covers
Includes cam covers, timing belt cover and coil cover.
Professionaly polished (cost over $500 alone)
'weld on' -10 fittings
$650
I also have a spare plenum which is gold, make an offer. Or add the polished plenum to the above for 250.
PM or email [email protected]
Do the cam covers have standard or aftermarket baffles?
if purchased as package with plenum will that include polished linkage assy?
Also what is it like to maintain this porn look?
Very interested.
The baffles are standard and the polished linkage assembly isn't included.
There is a bit of maintenance with this stuff - but when you start out with something in that sort of condition it's quite easy to look after. All the hard work has been done getting it perfectly smooth so touching it up is very easy.
Guest
    • https://www.nengun.com/hks/valcon-rb26-v-cam-system   no controller but most will use ECU to control anyhow
    • Not too sure, the throttle body has 4separate plugs going to it. Im not sure if the throttle is driven by cable and the motor is for traction, cruise and something there light blue one is TPS. i don't understand why the throttle won't open with the cable until about 3/4 on them only moves the valves very slightly
    • There are other crowds doing 25Neo conversion kits.
    • Not familiar with that car at all....but that code is for the traction control. Does it have a 2nd throttle in series with the first, like the R34 Neos do, to make the traction control happen?
    • Yeah good point, it won't flash on indicator that way, so plan B, just another wire to run from under the dash which makes it a bigger job 30 to indicator + globe side 86 tapped into 12v input to flasher relay under the dash (has 12v when indicators on, nothing when no indicators) 87a to headlight parker + 87 to original indicator + chassis side 85 to chassis/earth Now it will flash with indicators and be solid on with parkers
