Hi guys I have had this car almost since new, so about 9 years now and its now time to let it go.
The car is a 2001 ADM S15
EXTERIOR
- Resprayed to Honda S2000 red by J-RACING, this is a much deeper red than the Nissan colour
- Vertex rear + side skirts
- C-west Front bar
- Sunroof
- HID lights 6000k
ENGINE
- Head fully rebuilt 10000kms ago including the following parts purchased BRAND NEW
- Tomei Poncams
- Tomei Type A Valve Springs
- Tomei 1.0mm metal head gasket
- Brand new nissan VCT unit
- GKTech RAS
- ARP Headstuds
- 2871r 52T 0.64
- Tomei 740cc injectors
- Nismo fuel pump
- Apexi filter + Super Suction kit
- Apexi PFC
- Z32
- KOYO radiator
- RB25 clutch fan
- Oil Cooler with filter relocation kit
Engine parts that I had on the car for about 2 years prior to major mods
- Greddy Type S BOV
- Greddy VSPL FMIC
- 3" Xforce turboback stainless steel exhaust
- Tuned by Yavus at Unigroup Engineering for 246rwkw@18psi
DRIVELINE
- Custom 5 puck clutch from Western Clutches in Sydney
- Newly installed RB25 box by Powertune Sydney
- 4.11 final drive diff
- R33 tailshaft + driveshafts
SUSPENSION + BRAKES + WHEELS
- R33 GTR Brembos fronts + Project Mu 2 piece slotted rotors
- R33 Gts-t rears
- Motul RBF 600 fluid
- HKS Performer coilovers 6/4 springrates
- Whiteline adjustable front and rear swaybars
- Aftermarket adjustable front castor rods + rear camber arms
- Front strut brace
- Rays 19s in the pic which are a FORGED rim from a V35
INTERIOR
- Stock as a rock but in good nick
- Oops, no there is a GREDDY shiftknob
- And a Sony CD player
- And JBL speakers too
And all this for $18500
The car does has 138k on it but these are almost ALL highway kays from Canberra to Sydney as I work in one and live in the other. I am a mature owner of the car for the last 9 years and have done all the mods and have it serviced every 5000kms religiously with Motul fluids.
Car will also come with spares like front and rear S15 brakes, sway bars etc.
When the head was taken off for a rebuild the bottom end was inspected and I was told there was no reason to rebuild it as it all looked very good. At the time I was hoping to make 240rwkw to help save the 6 speed box so the bottom end was deemed to be more than fine for what I needed it to do. Compression test came back at 150 across all 4.
Unfortunately the box let go during the running in phase of the car hence I went to the RB25 box from Powertune.
PM me here or call 0414610499 if interested. Thanks for your time
https://www.sau.com.au/forums/topic/372861-s15-2001-adm/
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
