The funniest bit about all the 'it's a beta' blah blah blah is that the game has bugs from BC2. Like the sight bug where you will stop being able to look down the sights of your weapon until you switch weapons. This is kind of annoying in a firefight and why would I or anyone else have any expectation that it would be fixed given it is still a bug in BC2?
Edited by DivHunter
  • Replies 234
From the BF website
After analysing the data from our first round of closed Caspian Border tests, we have great news for participants in the Battlefield 3 PC Open Beta: the DICE team has decided to bring back Caspian Border for the beta’s final weekend and conduct an open large scale test of the 64 player Caspian Border map.
*****Please keep in mind that as this is beta we will be stress testing our servers***** As such, users may experience crashes, network instability and outages as we roll out and configure servers and network utilities. Understand that such potential issues and the testing environment are not reflective or indicative of the final product and that, through your participation, you will be helping to ensure future stability and functionality.
As we are again specifically testing 64-player server configurations, this test will be for PC only. The Caspian Border servers will be available for all PC players to join. Caspian Border will be available starting Friday, October 7th, in the afternoon (CET).
graphics look top notch.
what gfx are you running?
AMD 6950/70 2GB, its 1920x1200 on high settings, gets about 50-60fps average
that does look amazing...might have to waste some money and upgrade my computer for this one...its been a while!!
This. Me too. :P
oi nice, Ive got a 1gb 5770 lol
im running 1x 5770 as well and graphics are fine on high with 1300x1024 resolution, fps 40~
in talks with AMD and sapphire tech support cause im having issues finding a suitable driver to run 5770 cross fire smoothly.
currently using latest catalyst driver and when bench testing, the results in CF mode is the exact same results as running 1x 5770 (which should be 20-30fps higher in CF mode)
pretty disappointing as with my cards in cross fire mode, should run this game smoothly with min 50fps :(
thinking of getting a joystick as well, i find it so hard to fly jets/heli's with keyboard & mouse, i cant stay in the air longer then 5mins without crashing lol
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
