just fitted an safc2 to my s2 r33, and no go. Trialled it when i had just wired in the power and earth and it fired up fine...did the rest of the wiring and the ecu just kept clicking and safc kept restarting......caused by the squarish solenoid in behind the ecu, you can feel it clicking. Disconnected the afm wire and joined them back to bypass the safc, it fired up fine. Set all the settings in the safc, turned it off, went upstairs for a bit.......came back down and now it won't fire up at all, just keeps clicking/restarting??? cut all wires bar the ground and power, and still clicking. At a loss, cause I soldered all the joins, no way they have come loose?? anyone have any suggestions?
https://www.sau.com.au/forums/topic/372875-safc2-install-problem/
I have triple checked all connections, all were soldered securely. Checked I had tapped into the right pins, and all ok. This is seriously annoying. I'm not running anything else off the ecu - could the load of the safc be too much, causing it to keep tripping off?
ok - have found the car alarm might have something to do with it. When it has immobilised after 40 secs it was doing the tripping thing; when disarmed the safc comes on normally. So got it started and running. *But* found the check engine light coming on randomly once I started driving - stays on, then starts flashing, then quick flashes, long flashes, all over the place - doesn't seem to be in any order or code. So, bridged the consult plug to check for error codes, and nothing, just the 55 all clear flash. Car seems to drive alright but the fact the engine light keeps coming on and flashing can't be good.....plus a strong smell of melting plastic a few times too.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
