I found this inlet manifold adaptor to fit Rb26 inlet plenum and ITB's on the Rb25's plus they do a Rb20 version
At first I thought they did the old cut and weld option onto a rb25 inlet runners, but it is different
Then I thought they had done a cut and weld onto a rb25 greddy style inlet manifold, but no
I think they have made up a new casting with mounting plates to bolt the ITB's onto and have made a remote seperate IAC box. It does away with the rb26 injector section of the inlet.
The attached pic's are are R34 Rb25det version.
Having a close look at the adpator it looks the same a greddy style manifold around the injectors ports and mounts. The flange onto the ITB's looks to be a 1 piece casting, ie not welded onto the runners.
Also the reason I think it is not a greddy style manifold is the angle of the radiator hose connection.
It is square like a factory manifold and not at a angle like the greddy.
The main negative problems with either the Blitz style adaptor plate is the angle of the injectors and the cut and shunt to stock manifold is the different runner spacing and angles.
With this version they seem to have solved those issues, I can not see any problems or disadvantage with this design
Cost is not cheap at approx $700-750 plus post form Japan etc.
Does not include the rb26 setup, so add $300-400.
Your thoughts??
I have Neo rb25det with greddy style manifold already, but would luv ITB's with VCT
Edited by darrinspencer
I found them on Yahoo. I think it will be close to $950-1000 landed
http://www.importmonster.com.au/view?url=http://page6.auctions.yahoo.co.jp/jp/auction/f101401033&thumb=http://f6.auctions.c.yimg.jp/img321.auctions.yahoo.co.jp/users/2/4/5/6/assemble2006-thumb-1297139207470101.jpg&title=RB25 NEO6 GTR KIT
As mentioned, they do a Rb20, R33 Rb25 and R34 Neo kit.
No mention on the company who makes them
They look similar quality to the other cheap chinese greddy styles manifolds.
They only cost approx $150 wholesale price in china for example.
Might try and find the supplier/manufacture as I have a few contacts and inport some parts from china now.
I currently run the greddy style copy on my Neo with gt3076r
I am very keen to try one of these out and do back to back test.
It won't be be for at least to 6-8 weeks thuo.
I can't really see any negatives with this setup?
Anyone have any idea's??
i mean when you run the rb26 ITB's it apprently eliminates the vct.
I think that would happen when you use the full Rb26 intake with injector section and an adaptor plate as it would foul the VCT solnoid>
This kit is cast the same way, ie rad hose connection as the Rb25 manifold so it will clear the VCT. win win.
I have just email Aaron at IM to see if he can contact the seller and find out more info.
i found these on yahoo yesterday also after posting my comment.
although i could only find kits for rb20 and neo rb25
my rb25 is a s2 r33 engine.
definitely do more research into where the manifold is made, im eager to purchase asap
  • 3 months later...
    • Seems to be the case mate , still an OK price for a grey import.
    • I’m interested in the carbon diffuser fins and Toshiba MFD screen replacement if they’re still available.
    • @GTSBoy yeah i know it was not the "great" idea but it is and option...but i think i will stay on no BoV rather then trying to make it work with "half" this and that. But that GReddy FV2 is cool...i like that you can make it like stock if you want (and have/make the custom pipes) For other thanks! it was alot of information. But for the sound...a dont rly "like" both of them...specialy if they are loud...but if i "must" choose i would rather have little whooosh rather than sutututu with no BoV....BUT that is what is i gonna get. So for the all info i gather. In my case:  No BoV is not that bad cuz it is stock...and iam used to put N/clutch right after rpms are around 1000 so it should be ok...just need to avoid "big" drops. But i do not have the engine in the car so i do not really know how "bad" or good it is. But as i had that little test drive it looked ok. The atmo BoV should be worse car would dump to much fuel specialy between the shifts...so without proper tune/ECU i dont want that. BUT with that...car should drive ok with no problems right? (i do like there is less piping wih this solution) 🙂
    • Usually an RB20 won't stay in closed loop idle anyway. The O2 sensor gets too cold, stops swinging.
    • They aren't, but it depends on what interests you about an R32-R34. If it's the front engine I6 turbo that tunes well with a manual transmission an E92 335i 6MT is so incredibly cheap. You can get a super clean one for 20-25k USD tops. Put an LSD in it, tune it, have fun with it. If it's the general idea of AWD + turbo and a manual transmission the 996 Turbo is absolutely much more expensive, it's less practical but it's also basically a complete track-ready car from the factory. At least the Mezger doesn't have heaps of oil control issues. And in the US the 996 Turbo and R33 GTR are roughly the same price these days. 996 maybe a bit more now that the hype has abated for old Skylines here.
