I found this inlet manifold adaptor to fit Rb26 inlet plenum and ITB's on the Rb25's plus they do a Rb20 version
At first I thought they did the old cut and weld option onto a rb25 inlet runners, but it is different
Then I thought they had done a cut and weld onto a rb25 greddy style inlet manifold, but no
I think they have made up a new casting with mounting plates to bolt the ITB's onto and have made a remote seperate IAC box. It does away with the rb26 injector section of the inlet.
The attached pic's are are R34 Rb25det version.
Having a close look at the adpator it looks the same a greddy style manifold around the injectors ports and mounts. The flange onto the ITB's looks to be a 1 piece casting, ie not welded onto the runners.
Also the reason I think it is not a greddy style manifold is the angle of the radiator hose connection.
It is square like a factory manifold and not at a angle like the greddy.
The main negative problems with either the Blitz style adaptor plate is the angle of the injectors and the cut and shunt to stock manifold is the different runner spacing and angles.
With this version they seem to have solved those issues, I can not see any problems or disadvantage with this design
Cost is not cheap at approx $700-750 plus post form Japan etc.
Does not include the rb26 setup, so add $300-400.
Your thoughts??
I have Neo rb25det with greddy style manifold already, but would luv ITB's with VCT
Edited by darrinspencer
I found them on Yahoo. I think it will be close to $950-1000 landed
http://www.importmonster.com.au/view?url=http://page6.auctions.yahoo.co.jp/jp/auction/f101401033&thumb=http://f6.auctions.c.yimg.jp/img321.auctions.yahoo.co.jp/users/2/4/5/6/assemble2006-thumb-1297139207470101.jpg&title=RB25 NEO6 GTR KIT
As mentioned, they do a Rb20, R33 Rb25 and R34 Neo kit.
No mention on the company who makes them
They look similar quality to the other cheap chinese greddy styles manifolds.
They only cost approx $150 wholesale price in china for example.
Might try and find the supplier/manufacture as I have a few contacts and inport some parts from china now.
I currently run the greddy style copy on my Neo with gt3076r
I am very keen to try one of these out and do back to back test.
It won't be be for at least to 6-8 weeks thuo.
I can't really see any negatives with this setup?
Anyone have any idea's??
i mean when you run the rb26 ITB's it apprently eliminates the vct.
I think that would happen when you use the full Rb26 intake with injector section and an adaptor plate as it would foul the VCT solnoid>
This kit is cast the same way, ie rad hose connection as the Rb25 manifold so it will clear the VCT. win win.
I have just email Aaron at IM to see if he can contact the seller and find out more info.
i found these on yahoo yesterday also after posting my comment.
although i could only find kits for rb20 and neo rb25
my rb25 is a s2 r33 engine.
definitely do more research into where the manifold is made, im eager to purchase asap
  • 3 months later...
    • Sounds good. Provided the panel is flat/level I'd be happy to start the painting process.  While you are learning, for sure you could do this. Its only paint, you can always sand it all back and start again. Its only your time and money on materials, but while you're learning, really its time and money spent on your education.  Once you know how to do this bodywork and painting, you won't want to waste your time and money on frivolous activities lol.
    • Yep I will use a guide coat after putting filler, I will do it on the whole panel as I'm a beginner so chances I've made quite a few errors. In that photo, I think that was a low spot, I just for example said to pretend it's flat but I will put filler + guide coat after to assess where I'm at. Yep with that picture, the panel is wet as it rained when I took the photo. But all those scratches are completely smooth, I went over it with 240 grit and can't feel it, even with my nail digging into it. I was legit thinking to buy a 2k can and spray primer to see how it turns out but then thought to myself it's going to be a mess doing it haha. Good mention there. Thanks for all that info I think I know what to do next.
    • Prior to laying down the primer, you need to make sure the surface is completely level. For example, based on this picture, I strongly suspect that the areas marked in blue are higher then the area marked in green.  If you spray primer over this entire area, then paint and clear it, the finished result will 100% show the low area. It will stick out like dogs balls. Unfortunately the paint won't magically level out the low areas as you lay it down.  Without seeing it in person, I expect that the green area will need to be filled, then use a guide coat and check that the entire repair area is level with a large sanding block.  With this picture, are you saying that even though you can see the scratches, the panel is in fact completely smooth and flat? If this is the case sure you could prep and paint it as it is.     The picture with the paint you described as blistering, it's hard for me to comment on from the photo alone. It looks like the panel is wet? Dunno, looks strange. Does the panel feel as smooth as glass when you run your hand over it? **** Going back to your question again, generally you would only sand the primer if you made a mistake while laying down the primer.  If the panel is prepped properly and you lay the primer down properly, you should not need to sand the primer.  This wouldn't work - Don't prep the panel. Spray primer and see how it turns out. Sand the areas where the issues appear. Spray more primer and see how it turns out. Sand the areas....... Yeah you'd go round and round in circles getting no where.
    • That's sick, thanks for that, mine has much the same mods on a 400R. I just don't have the heat exchanger yet.   Might be worth a trip down the M1 to Syndey for a tune.
    • Mate , this is the current mods list Current Mods list (Installed) RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler AMS Alpha Performance Full Race Down Pipes ECUTEK tune form TuneHouse in Sydney .(Just over 2k) The car came with HKS - Power Editor but I had it removed for the full tune. I would say if you are using the car for street diving a proper tune would be better.
