Hey guys,
Having a clean up sale, found some items whilst moving out, and some came off the new car.
1. Momo Race 350mm steering wheel
a little worn
$100 posted
2. Topstage S14.5 Guards
Brand new, no longer going ahead with conversion
$250 posted
3. Universal rails
Brand new, make your own custom rails
$40 each posted or $70 pair posted
4. Greddy catch can
New car has catch can, so no need
$80 posted
5. Nissan Skyline/Stagea intake kit
Has no BOV inlet
$120 posted
6. Universal side mount seat rails
No need for them
$30 pair, or $50 for all posted
7. Oil cooler with with oil filter relocation
New car has a kit, no need. Has a few rub marks still holds pressure. Unsure of brand.
$250 posted
8. H4 HID kit
Hi/lo beams brand new
$80 posted
9. Tanabe undercarriage brace
Stiffen up that Stagea
$200 shipped
10. Stagea rear cradle package
Reduce the rear track on your Stagea with the following
S14 turbo rear subframe
R33 5 bolt half shafts
$200 or $250 shipped
11. Nissan Stagea NA Grille
$100 or $120 posted
12. Also got my worksbell boss kit for C34 Stagea for sale. Includes horn wiring and airbag light bypass, simply install with no fuss.
$100 shipped.
Located in Liverpool region
PM me or text on 0410-65-1989
Adam.
Edited by Run-It-Hard
https://www.sau.com.au/forums/topic/372933-run-it-hard-garage-sale/
item 10 revised.
10. S14 turbo rear subframe
Great for reducing rear track in Automatic Stageas, eliminating HICAS in Skylines etc
$ 80 or $120 shipped
They won't bolt up to anything without Malone brackets.
READ BELOW!
Please read this whole thread before PMing me, I am getting sick of PM's for things that were sold a month ago, I have stated in the thread what is sold. I will not reply to PM's for items have been already sold.
Thanks.
READ BELOW!
Thanks.
So does that mean item #3 is sold. I didnt see it marked as such. If not, i'd be interested in them.
Thanx,
Ian
Nahs those aren't sold Ian, I've just been getting PM's the past week for things that are sold and it's driving me mad!
You'll need to make mounts for the seats and to bolt into the car for them though, a bit of work.
Ok, no sweat. You still at the same address or have you moved?
Let me know on 0423 204 997.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
