  • Replies 301
Posted Images
a few pics of the sa crew
DSC_0005 by peterjamesmedia, on Flickr
DSC_0015 by peterjamesmedia, on Flickr
DSC_0029 by peterjamesmedia, on Flickr
DSC_0064_1 by peterjamesmedia, on Flickr
DSC_0305_1 by peterjamesmedia, on Flickr
DSC_0349_1 by peterjamesmedia, on Flickr
DSC_0366 by peterjamesmedia, on Flickr
DSC_0368_1 by peterjamesmedia, on Flickr
DSC_0350 by peterjamesmedia, on Flickr
DSC_0394_1 by peterjamesmedia, on Flickr
DSC_0380_1 by peterjamesmedia, on Flickr
DSC_0375 by peterjamesmedia, on Flickr
Love those shots Pete - really nice camera setup you have there!
Can I please grab any shots anyyone has of my car in full resolution emailed to andnus at adam dot com dot au? Thanks!
No-one really broke much .... and I did a 1:49.3 best in my 183rwkw V35 daily, from memory Josh did a 1:46 in his 270rwkw GTST, Red Back in his 280awkw R33GTR did a low 1:45 in the first session (then did 2 sessions at unknowingly low boost = split an intercooler hose and retired for the day), Andrew from AM Performance did a 1:46 in his 300rwkw R33GTST from memory, and Ryan from ISC coilovers did a 1:43 best in his S14 to take out 2nd place in modified rwd class!
Actually, even better - go and have a look for yourselves :)
http://www.natsoft.com.au/cgi-bin/results.cgi?29/10/2011.WIN.P1
http://www.natsoft.com.au/cgi-bin/results.cgi?29/10/2011.WIN.S1
http://www.natsoft.com.au/cgi-bin/results.cgi?29/10/2011.WIN.S2
http://www.natsoft.com.au/cgi-bin/results.cgi?29/10/2011.WIN.S3
http://www.natsoft.com.au/cgi-bin/results.cgi?29/10/2011.WIN.S4
http://www.natsoft.com.au/cgi-bin/results.cgi?29/10/2011.WIN.S5
For some sad reason the timing gear stuffed up and a heap of people's lap times were not recorded in some sessions :( .... I am not sure how this can happen when I thought we were using the same gear that the Supercars use, but hey, it happened.
Yeah a major and utter c0ck up on Winton's behalf, especially for Session 3 :rant:
Especially given the amount of money they were paid to "organise" it...
Oh well... Not much we can do unfortunately as if they are lost, they ain't coming back. Just really disappointing overall.
Good times for all you guys having never been on it before.
Andrew, Ryan actually did a low 1:40......spewing he didn't break into the 30's....his S14 is clearly capable of it
Had a blast out there! Every session I went out I knocked nearly a second off. Last session of the day a had 4 x 1:40.xx in a row but no 1:39 >_<
will definetly be heading back there soon, great track to drive!
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
