  • Replies 301
Posted Images
a few pics of the sa crew
DSC_0005 by peterjamesmedia, on Flickr
DSC_0015 by peterjamesmedia, on Flickr
DSC_0029 by peterjamesmedia, on Flickr
DSC_0064_1 by peterjamesmedia, on Flickr
DSC_0305_1 by peterjamesmedia, on Flickr
DSC_0349_1 by peterjamesmedia, on Flickr
DSC_0366 by peterjamesmedia, on Flickr
DSC_0368_1 by peterjamesmedia, on Flickr
DSC_0350 by peterjamesmedia, on Flickr
DSC_0394_1 by peterjamesmedia, on Flickr
DSC_0380_1 by peterjamesmedia, on Flickr
DSC_0375 by peterjamesmedia, on Flickr
Love those shots Pete - really nice camera setup you have there!
Can I please grab any shots anyyone has of my car in full resolution emailed to andnus at adam dot com dot au? Thanks!
No-one really broke much .... and I did a 1:49.3 best in my 183rwkw V35 daily, from memory Josh did a 1:46 in his 270rwkw GTST, Red Back in his 280awkw R33GTR did a low 1:45 in the first session (then did 2 sessions at unknowingly low boost = split an intercooler hose and retired for the day), Andrew from AM Performance did a 1:46 in his 300rwkw R33GTST from memory, and Ryan from ISC coilovers did a 1:43 best in his S14 to take out 2nd place in modified rwd class!
Actually, even better - go and have a look for yourselves :)
http://www.natsoft.com.au/cgi-bin/results.cgi?29/10/2011.WIN.P1
http://www.natsoft.com.au/cgi-bin/results.cgi?29/10/2011.WIN.S1
http://www.natsoft.com.au/cgi-bin/results.cgi?29/10/2011.WIN.S2
http://www.natsoft.com.au/cgi-bin/results.cgi?29/10/2011.WIN.S3
http://www.natsoft.com.au/cgi-bin/results.cgi?29/10/2011.WIN.S4
http://www.natsoft.com.au/cgi-bin/results.cgi?29/10/2011.WIN.S5
For some sad reason the timing gear stuffed up and a heap of people's lap times were not recorded in some sessions :( .... I am not sure how this can happen when I thought we were using the same gear that the Supercars use, but hey, it happened.
Yeah a major and utter c0ck up on Winton's behalf, especially for Session 3 :rant:
Especially given the amount of money they were paid to "organise" it...
Oh well... Not much we can do unfortunately as if they are lost, they ain't coming back. Just really disappointing overall.
Good times for all you guys having never been on it before.
Andrew, Ryan actually did a low 1:40......spewing he didn't break into the 30's....his S14 is clearly capable of it
Had a blast out there! Every session I went out I knocked nearly a second off. Last session of the day a had 4 x 1:40.xx in a row but no 1:39 >_<
will definetly be heading back there soon, great track to drive!
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
