  • Replies 300
Fuc$ you do a lot of flat bench press, maybe try doing more incline
I don't have an incline yet but when I do my pressing sessions will consist of flat bench, incline bench and overhead press. It has been said, to press a lot you must press a lot. Pressing on all angles makes you strong everywhere.
Bit of a side note, all the flat bench I did for years was with a close grip. The last few months I changed to a very wide grip. I was pretty weak at the beginning but eventually worked up to my 1RM with a wide grip in <3months. The wide grip is pretty impractical unless the goal is a power lift (reduced rom etc) because the wide grip hurts the crap out of my wrists and the movement feels stupid. I'm now using a middle grip which is in between close and wide grip and it feels great - works triceps and lats without feeling like it favours one over the other which the other grips did.
A few weeks ago I started following a simple plan of 5 sets 10 reps, if I get at least 7-8 reps on the last 2 sets then up the weight by 2.5kg. It's going great. Squats are really challenging (127.5kg next session) and bench feels a lot more solid now that I'm building up the volume and getting my upperbody used to doing a decent workload.
Weighed 74.5kg yesterday which is the most I've ever weighed so my diet is going well :)
Edited by GHOSTrun
23/1/12
BP
bar x 10
40kg x 10
60kg x 10
77.5kg x 10
77.5kg x 9
77.5kg x 9
77.5kg x 7
77.5kg x 7
Single arm KB rows
32kg x 10
32kg x 10
32kg x 10
MP
45kg x 10
45kg x 9
45kg x 12
Pullups
10,8,9
Chinups
10,10,2..lol buggered
27/1/12
BP
bar x 10
40kg x 12
60kg x 10
80kg x 9
80kg x 8
80kg x 7
80kg x 6
80kg x 5
Single arm KB rows
32kg x 12
32kg x 12
32kg x 12
Dips
14,12,10
Pullups
5,5,5,5,5
MP
47.5kg x 10
47.5kg x 9
47.5kg x 8
Chinups
5,5,5,5,5
Front plate raises
25kg x 10
25kg x 10
25kg x 10
Started in 2005, first ~2 years didn't know anything about training, just did bro curls and the usual shit etc.
Then got introduced to the fitness diet and bodybuilding section on ns.com and met Markos, where I learnt a lot, changed the way I train etc.
Since then have been lifting on and off, never as consistantly as I'd like which is why others have made much better gains in the same space of time.
At the end of last year my Fitness First membership expired and I changed to PTC Brisbane in Kallangar and have been training there ever since every Monday/Wednesday/Friday and have only missed 3 sessions in that whole time.
It's around 40mins drive for me to get there but it's worth it. It's a porper lifting environment to get strong. Very hard to achieve the same results in a regular gym.
Edited by GHOSTrun
Having a room full of the best equipment doesn't make a good gym.
The people who train at a gym make it a good gym.
This is what I mean by "the right lifting environment".
If you've never trained at one you won't understand.
I used to have my own gym setup in my garage, made good progress but stalled.
The progress I've made whilst training at PTC has been much better.
I'm not saying you have to train at a specific place to get better, I'm saying that it has helped me.
Edited by GHOSTrun
Nice. I know what you mean by the right gym., it's all about the atmosphere/vibe
That's fair enough, like I said it's just my view. My gym is full of f**kheads and arrogant smelly Indians who all think they're massive, but I train how I want and wouldn't train any differently no matter where I was
10/2/12
BP
Bar x 10
40kg x 10
60kg x 10
80kg x 7
80kg x 7
80kg x 7
80kg x 6
80kg x 4
CGBP
60kg x 14
60kg x 10
60kg x 8
Single Arm KB Rows
32kg x 15
32kg x 15
Pullups
10,8
Front Plate Raises
25kg x 10
25kg x 10
KB Side Lateral Raises
6kg x 10
6kg x 10
Combine lat pull down with over grasp pull ups, when u can do any more
Pull ups, jump to the top and do negatives... Works a mint
I might also be joining a Stepz 24/7 gym that's only a hundred meters down the road to go there on the odd days to do the ancillary work that PTC doesn't have that sort of equipment to cater for such as lat pulldown, cable row, dumbbells etc
13/2/12
BP
bar x 20
40kg x 10
60kg x 10
80kg x 6
80kg x 6
80kg x 6
80kg x 6
80kg x 4
80kg x 3
60kg x 14
60kg x 12
60kg x 10
60kg x 11
60kg x 10
60kg x 10
60kg x 9
60kg x 5
CGBP
60kg x 7
60kg x 5
60kg x 6
Single Arm KB Row
32kg x 15
24kg x 18
24kg x 12
Pullups - 5
Chinups - 5
Front Plate Raises - 25kg x 10
KB Side Lateral Raises - 6kg x 10
17/2/12
BP
bar x 20
40kg x 10
60kg x 10
80kg x 7
80kg x 6
80kg x 5
80kg x 6
80kg x 5
75kg x 6
75kg x 7
75kg x 5
75kg x 4
75kg x 5
CGBP
70kg x 5
70kg x 5
70kg x 5
70kg x 5
70kg x 5
60kg x 8
60kg x 8
60kg x 7
60kg x 7
60kg x 7
22/2/12
SQ
bar x 10
40kg x 10
70kg x 10
90kg x 5
137.5kg x 10
137.5kg x 8
137.5kg x 7
137.5kg x 6
137.5kg x 5
137.5kg x 3...was in the hole on no.4, came forward too much then both calves cramped at the same time, gently dumped the bar onto the pins and lay on the ground for the next 5 minutes in more pain then I can ever remember.
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it    Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher      I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
