  • Replies 300
Fuc$ you do a lot of flat bench press, maybe try doing more incline
I don't have an incline yet but when I do my pressing sessions will consist of flat bench, incline bench and overhead press. It has been said, to press a lot you must press a lot. Pressing on all angles makes you strong everywhere.
Bit of a side note, all the flat bench I did for years was with a close grip. The last few months I changed to a very wide grip. I was pretty weak at the beginning but eventually worked up to my 1RM with a wide grip in <3months. The wide grip is pretty impractical unless the goal is a power lift (reduced rom etc) because the wide grip hurts the crap out of my wrists and the movement feels stupid. I'm now using a middle grip which is in between close and wide grip and it feels great - works triceps and lats without feeling like it favours one over the other which the other grips did.
A few weeks ago I started following a simple plan of 5 sets 10 reps, if I get at least 7-8 reps on the last 2 sets then up the weight by 2.5kg. It's going great. Squats are really challenging (127.5kg next session) and bench feels a lot more solid now that I'm building up the volume and getting my upperbody used to doing a decent workload.
Weighed 74.5kg yesterday which is the most I've ever weighed so my diet is going well :)
Edited by GHOSTrun
23/1/12
BP
bar x 10
40kg x 10
60kg x 10
77.5kg x 10
77.5kg x 9
77.5kg x 9
77.5kg x 7
77.5kg x 7
Single arm KB rows
32kg x 10
32kg x 10
32kg x 10
MP
45kg x 10
45kg x 9
45kg x 12
Pullups
10,8,9
Chinups
10,10,2..lol buggered
27/1/12
BP
bar x 10
40kg x 12
60kg x 10
80kg x 9
80kg x 8
80kg x 7
80kg x 6
80kg x 5
Single arm KB rows
32kg x 12
32kg x 12
32kg x 12
Dips
14,12,10
Pullups
5,5,5,5,5
MP
47.5kg x 10
47.5kg x 9
47.5kg x 8
Chinups
5,5,5,5,5
Front plate raises
25kg x 10
25kg x 10
25kg x 10
Started in 2005, first ~2 years didn't know anything about training, just did bro curls and the usual shit etc.
Then got introduced to the fitness diet and bodybuilding section on ns.com and met Markos, where I learnt a lot, changed the way I train etc.
Since then have been lifting on and off, never as consistantly as I'd like which is why others have made much better gains in the same space of time.
At the end of last year my Fitness First membership expired and I changed to PTC Brisbane in Kallangar and have been training there ever since every Monday/Wednesday/Friday and have only missed 3 sessions in that whole time.
It's around 40mins drive for me to get there but it's worth it. It's a porper lifting environment to get strong. Very hard to achieve the same results in a regular gym.
Edited by GHOSTrun
Having a room full of the best equipment doesn't make a good gym.
The people who train at a gym make it a good gym.
This is what I mean by "the right lifting environment".
If you've never trained at one you won't understand.
I used to have my own gym setup in my garage, made good progress but stalled.
The progress I've made whilst training at PTC has been much better.
I'm not saying you have to train at a specific place to get better, I'm saying that it has helped me.
Edited by GHOSTrun
Nice. I know what you mean by the right gym., it's all about the atmosphere/vibe
That's fair enough, like I said it's just my view. My gym is full of f**kheads and arrogant smelly Indians who all think they're massive, but I train how I want and wouldn't train any differently no matter where I was
10/2/12
BP
Bar x 10
40kg x 10
60kg x 10
80kg x 7
80kg x 7
80kg x 7
80kg x 6
80kg x 4
CGBP
60kg x 14
60kg x 10
60kg x 8
Single Arm KB Rows
32kg x 15
32kg x 15
Pullups
10,8
Front Plate Raises
25kg x 10
25kg x 10
KB Side Lateral Raises
6kg x 10
6kg x 10
Combine lat pull down with over grasp pull ups, when u can do any more
Pull ups, jump to the top and do negatives... Works a mint
I might also be joining a Stepz 24/7 gym that's only a hundred meters down the road to go there on the odd days to do the ancillary work that PTC doesn't have that sort of equipment to cater for such as lat pulldown, cable row, dumbbells etc
13/2/12
BP
bar x 20
40kg x 10
60kg x 10
80kg x 6
80kg x 6
80kg x 6
80kg x 6
80kg x 4
80kg x 3
60kg x 14
60kg x 12
60kg x 10
60kg x 11
60kg x 10
60kg x 10
60kg x 9
60kg x 5
CGBP
60kg x 7
60kg x 5
60kg x 6
Single Arm KB Row
32kg x 15
24kg x 18
24kg x 12
Pullups - 5
Chinups - 5
Front Plate Raises - 25kg x 10
KB Side Lateral Raises - 6kg x 10
17/2/12
BP
bar x 20
40kg x 10
60kg x 10
80kg x 7
80kg x 6
80kg x 5
80kg x 6
80kg x 5
75kg x 6
75kg x 7
75kg x 5
75kg x 4
75kg x 5
CGBP
70kg x 5
70kg x 5
70kg x 5
70kg x 5
70kg x 5
60kg x 8
60kg x 8
60kg x 7
60kg x 7
60kg x 7
22/2/12
SQ
bar x 10
40kg x 10
70kg x 10
90kg x 5
137.5kg x 10
137.5kg x 8
137.5kg x 7
137.5kg x 6
137.5kg x 5
137.5kg x 3...was in the hole on no.4, came forward too much then both calves cramped at the same time, gently dumped the bar onto the pins and lay on the ground for the next 5 minutes in more pain then I can ever remember.
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
