  • Replies 300
27/2/12
BP
bar x 10
40kg x 10
60kg x 10
80kg x 8
80kg x 8
80kg x 6
80kg x 7
80kg x 6
RGBP
60kg x 10
60kg x 10 (GB)
60kg x 10 (GB)
WGBP
70kg x 6
70kg x 6
70kg x 5
CGBP
70kg x 1
60kg x 8
60kg x 8
60kg x 7
KB Swings
40kg x 25
Pullups
5,5,5,5,5
KB Side Laterals
4kg x 20
4kg x 20
4kg x 20
KB Rear Delt Raises
4kg x 20
4kg x 20
4kg x 20
29/2/12
SQ
bar x 10
40kg x 10
70kg x 10
90kg x 5
140kg x 7
140kg x 6
140kg x 5
140kg x 5
140kg x 5
140kg x 4
140kg x 2
Box SQ (40cm box)
180kg x 4
Heart wasn't in it tonight, too tired and drained from work these last few weeks. Hit 75.2kg bw the other day but haven't been eating well because very busy at work and massive stress - projects approaching deadlines, little sleep. Hovering around 73-74kg.
http://www.youtube.com/watch?v=w47b614G1kU
http://www.youtube.com/watch?v=JaIAmqDRmQI
Edited by GHOSTrun
12/3/12
BP
bar x 20
40kg x 10
60kg x 10
80kg x 10
80kg x 6
80kg x 6
80kg x 4
80kg x 6
RGBP
60kg x 10
60kg x 9
CGBP
60kg x 10
60kg x 10
Pullups
10,10
Side Lateral Raises (KB)
8kg x 10
8kg x 10
Rear Delt Raises (KB)
6kg x 10
6kg x 10
Front Plate Raises
25kg x 10
25kg x 10
19/3/12
BP
bar x 10
40kg x 10
60kg x 10
80kg x 10
80kg x 8
80kg x 7
80kg x 7
80kg x 5
RGBP
70kg x 7
70kg x 9
70kg x 8
CGBP
60kg x 10
60kg x 9
60kg x 5
Pullups
12,5
KB Side Lateral Raises
8kg x 10
8kg x 6
KB Rear Delt Raises
6kg x 10
6kg x 10
Front Plate Raises
25kg x 10
25kg x 6
KB Curls
14kg x 20
28/3/12
SQ
bar x 10
40kg x 10
70kg x 10
90kg x 10
120kg x 16
Pullups
7
KB Curls
16kg x 15
Just an easy session tonight. Pulled a rhomboid or lat (something in my middle back) moving a fridge last weekend and that's still nagging.
Edited by GHOSTrun
2/4/12
BP
bar x 20
40kg x 20
60kg x 21
80kg x 9
80kg x 8
80kg x 6
RGBP
70kg x 11
70kg x 8
70kg x 7
CGBP
60kg x 10
Trap Bar Bent Rows (TBBR)
65kg x 10
65kg x 10
65kg x 10
65kg x 10
Single Arm KB Rows
24kg x 10
24kg x 10
24kg x 10
8kg x 10
8kg x 10
KB Rear Delt Raises
6kg x 10
6kg x 5
Weighed 74.95kg yesterday, knocking on the door of 75! lol :)
9/4/12
BP
Bar x 20
40kg x 20
60kg x 25
80kg x 10
80kg x 8
80kg x 8
RGBP
70kg x 10
70kg x 8
70kg x 10
CGBP
60kg x 10
TBBR
65kg x 10
65kg x 10
65kg x 10
65kg x 10
Single arm KB rows
24kg x 10
24kg x 10
24kg x 10
24kg x 10
Side lateral raises (KB)
8kg x 10
8kg x 10
Rear dealt raises (KB)
8kg x 10
8kg x 10
Front plate raises
20kg x 10
20kg x 10
16/4/12
Squat
bar x 10
40kg x 10
70kg x 10
120kg x 10
140kg x 8 (new PB)
165kg x 1 (new PB)
170kg x 1 (new PB)
Bench Press
bar x 20
40kg x 20
60kg x 22
80kg x 12 (new PB)
80kg x 9
80kg x 8
Reverse Grip Bench Press
70kg x 11
70kg x 12
70kg x 7
Close Grip Bench Press
60kg x 9
60kg x 10
Trap Bar Bent Rows
65kg x 10
65kg x 10
65kg x 10
Single arm KB rows
24kg x 10
24kg x 10
24kg x 10
Edited by GHOSTrun
BP
bar x 20
40kg x 20
60kg x 26
80kg x 8
80kg x 10
80kg x 6
80kg x 8
80kg x 6
RGBP
70kg x 7
70kg x 8
70kg x 6
CGBP
60kg x 8
60kg x 8
60kg x 7
60kg x 7
Single Arm KB Rows
28kg x 10
28kg x 10
28kg x 10
28kg x 10
Trap Bar Ben Rows
75kg x 10
8kg x 10
8kg x 5 + 5
KB Rear Delt Raises
8kg x 10
8kg x 10
MP
40kg x 7
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
