SQ
bar x 10
40kg x 10
60kg x 10
80kg x 10
100kg x 10
100kg x 10
100kg x 10
Single Arm DB Rows
20kg x 10
20kg x 10
20kg x 10
DB MP
20kg x 10
20kg x 10
20kg x 10
DB Curls
20kg x 10
20kg x 10
FPR's
20kg x 10
20kg x 10
20/3/13
BP
bar x 10
40kg x 10
60kg x 18
60kg x 10
60kg x 9
Single Arm DB Rows
22.5kg x 10
22.5kg x 10
22.5kg x 10
DB Curls
22.5kg x 10
22.5kg x 10
FPR's
20kg x 10
20kg x 10
20kg x 10
SLDL
100kg x 20
DB MP
22.5kg x 5
22.5kg x 5
  • Replies 300
26/3/13
SQ
bar x 10
40kg x 10
70kg x 10
90kg x 10
120kg x 5
120kg x 5
120kg x 5
120kg x 5
120kg x 5
122.5kg x 1
125kg x 1
127.5kg x 1
130kg x 1
132.5kg x 1
135kg x 1
137.5kg x 1
140kg x 1
DB MP
22.5kg x 10
22.5kg x 10
22.5kg x 5
Single Arm DB Rows
30kg x 10
30kg x 10
30kg x 10
DB Curls
22.5kg x 10
22.5kg x 8
20kg x 8
15kg x 5
+ a few more sets at the end
FPR's
20kg x 12
20kg x 12
20kg x 12
I'm assuming there's some PL comp on Saturday? I can't unfortunately, just too busy with work and family at the moment, I barely even get to the gym once a week/fortnight/month! :(
Edited by GHOSTrun
  • 4 weeks later...
30/4/13
BP
bar x 10
40kg x 10
60kg x 10
60kg x 10
60kg x 10
SQ
bar x 10
40kg x 10
70kg x 10
90kg x 10
122.5kg x 5
122.5kg x 5
122.5kg x 5
122.5kg x 5
122.5kg x 5
Incline DB BP
20kg x 10
25kg x 10
25kg x 7
25kg x 6
20kg x 10
20kg x 7
Single Arm DB Rows
30kg x 10
30kg x 10
30kg x 10
FPR's
20kg x 10
20kg x 10
20kg x 10
  • 1 month later...
23/6/13
BP
40kg x 10
70kg x 5
70kg x 5
70kg x 5
70kg x 5
70kg x 5
Trap Bar Bent Rows
75kg x 10
75kg x 10
75kg x 10
DB Bench Press
20kg x 10
20kg x 10
20kg x 10
Single Arm DB Rows
35kg x 5
35kg x 5
35kg x 5
Built myself a small setup for home. As much as I'd like to train at PTC Brisbane, it just wasn't working for me to get their after work multiple times a week.
1011750_10151710698858945_301692540_n.jp
992891_10151715238558945_1055484413_n.jp
1013452_10151723642698945_343515929_n.jp
941709_10151723675503945_1200390835_n.jp
Haven't finished trimming the bench yet because I'm still playing around with the foam specs to get it how I want, bit more trial and error.
1/7/13
Squat
80kg x 30
90kg x 3
100kg x 3
120kg x 6
130kg x 6
140kg x 2
Pause Squat
100kg x 5
100kg x 5
100kg x 5
1/8th Squat
170kg x 5
170kg x 5
170kg x 5
Front Squat
70kg x 5
70kg x 5
70kg x 5
Shadow of my former-self, would like to get back to where I was, will take some time though, at the moment I just have no passion for lifting, and when something that's supposed to be enjoyable becomes a chore, why do it at all. The bug will bite again, it always does, just get sidetracked with other stuff in life every now and then etc.
  • 1 month later...
  • 3 weeks later...
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
