  • Replies 300
27/2/12
BP
bar x 10
40kg x 10
60kg x 10
80kg x 8
80kg x 8
80kg x 6
80kg x 7
80kg x 6
RGBP
60kg x 10
60kg x 10 (GB)
60kg x 10 (GB)
WGBP
70kg x 6
70kg x 6
70kg x 5
CGBP
70kg x 1
60kg x 8
60kg x 8
60kg x 7
KB Swings
40kg x 25
Pullups
5,5,5,5,5
KB Side Laterals
4kg x 20
4kg x 20
4kg x 20
KB Rear Delt Raises
4kg x 20
4kg x 20
4kg x 20
29/2/12
SQ
bar x 10
40kg x 10
70kg x 10
90kg x 5
140kg x 7
140kg x 6
140kg x 5
140kg x 5
140kg x 5
140kg x 4
140kg x 2
Box SQ (40cm box)
180kg x 4
Heart wasn't in it tonight, too tired and drained from work these last few weeks. Hit 75.2kg bw the other day but haven't been eating well because very busy at work and massive stress - projects approaching deadlines, little sleep. Hovering around 73-74kg.
http://www.youtube.com/watch?v=w47b614G1kU
http://www.youtube.com/watch?v=JaIAmqDRmQI
Edited by GHOSTrun
12/3/12
BP
bar x 20
40kg x 10
60kg x 10
80kg x 10
80kg x 6
80kg x 6
80kg x 4
80kg x 6
RGBP
60kg x 10
60kg x 9
CGBP
60kg x 10
60kg x 10
Pullups
10,10
Side Lateral Raises (KB)
8kg x 10
8kg x 10
Rear Delt Raises (KB)
6kg x 10
6kg x 10
Front Plate Raises
25kg x 10
25kg x 10
19/3/12
BP
bar x 10
40kg x 10
60kg x 10
80kg x 10
80kg x 8
80kg x 7
80kg x 7
80kg x 5
RGBP
70kg x 7
70kg x 9
70kg x 8
CGBP
60kg x 10
60kg x 9
60kg x 5
Pullups
12,5
KB Side Lateral Raises
8kg x 10
8kg x 6
KB Rear Delt Raises
6kg x 10
6kg x 10
Front Plate Raises
25kg x 10
25kg x 6
KB Curls
14kg x 20
28/3/12
SQ
bar x 10
40kg x 10
70kg x 10
90kg x 10
120kg x 16
Pullups
7
KB Curls
16kg x 15
Just an easy session tonight. Pulled a rhomboid or lat (something in my middle back) moving a fridge last weekend and that's still nagging.
Edited by GHOSTrun
2/4/12
BP
bar x 20
40kg x 20
60kg x 21
80kg x 9
80kg x 8
80kg x 6
RGBP
70kg x 11
70kg x 8
70kg x 7
CGBP
60kg x 10
Trap Bar Bent Rows (TBBR)
65kg x 10
65kg x 10
65kg x 10
65kg x 10
Single Arm KB Rows
24kg x 10
24kg x 10
24kg x 10
8kg x 10
8kg x 10
KB Rear Delt Raises
6kg x 10
6kg x 5
Weighed 74.95kg yesterday, knocking on the door of 75! lol :)
9/4/12
BP
Bar x 20
40kg x 20
60kg x 25
80kg x 10
80kg x 8
80kg x 8
RGBP
70kg x 10
70kg x 8
70kg x 10
CGBP
60kg x 10
TBBR
65kg x 10
65kg x 10
65kg x 10
65kg x 10
Single arm KB rows
24kg x 10
24kg x 10
24kg x 10
24kg x 10
Side lateral raises (KB)
8kg x 10
8kg x 10
Rear dealt raises (KB)
8kg x 10
8kg x 10
Front plate raises
20kg x 10
20kg x 10
16/4/12
Squat
bar x 10
40kg x 10
70kg x 10
120kg x 10
140kg x 8 (new PB)
165kg x 1 (new PB)
170kg x 1 (new PB)
Bench Press
bar x 20
40kg x 20
60kg x 22
80kg x 12 (new PB)
80kg x 9
80kg x 8
Reverse Grip Bench Press
70kg x 11
70kg x 12
70kg x 7
Close Grip Bench Press
60kg x 9
60kg x 10
Trap Bar Bent Rows
65kg x 10
65kg x 10
65kg x 10
Single arm KB rows
24kg x 10
24kg x 10
24kg x 10
Edited by GHOSTrun
BP
bar x 20
40kg x 20
60kg x 26
80kg x 8
80kg x 10
80kg x 6
80kg x 8
80kg x 6
RGBP
70kg x 7
70kg x 8
70kg x 6
CGBP
60kg x 8
60kg x 8
60kg x 7
60kg x 7
Single Arm KB Rows
28kg x 10
28kg x 10
28kg x 10
28kg x 10
Trap Bar Ben Rows
75kg x 10
8kg x 10
8kg x 5 + 5
KB Rear Delt Raises
8kg x 10
8kg x 10
MP
40kg x 7
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
