All into 1 thread.
A fair bit of this stuff is for sale in other threads I've made, but never moved.
Need it gone.
Series 2 / 3 Air ConControls
The plastic on the back is all busted up from me not being gentle enough with it, barely holds together.
The face is slightly different to the Cefiro units.
Electronically, it's all good, but without being inside a proper casing, some buttons don't reach the switches
You can take the face / internals and put it into another casing, and it'll be all good.
$20
HKS Turbo Timer
Old School. Suits Series 2/3 Laurel, R32 Skyline. I've cut part of the harness out so you can turn it around and it'll suit Series 1 Cefiro and Laurel.
$20
DRIFT Gear Shift Knob
Has a fair bit of weight in it.
The plastic adapter to suit Nissan thread is a bit buggered, but it still does the job.
The scratches look a lot worse in the photo's than they actually are.
$100
Auto HeadlightSensor
Suit A31 Cefiro / C33 Laurel.
$10
HICAS Computer
$10
Weird Brown Box
Mounts between the brake booster and the upper chassis rail in the engine bay.
Headlight/Indicator & Window Wiper Stalk
Need a scrub and clean. Markings have faded off.
$20 for BOTH
Cefiro/Laurel CD Player DIN Mounting Brackets.
$20
Nachi Thrust Bearing
Suit RB. Part # TBA342
Never Used, still in packaging. Box in shit shape.
$50
Various Holding Devices.Throttle Cable (Strut Tower), Fuel Filter (Strut Tower), Loom/Air ConPipe (Chassis), Glove Box Clip.
$Make Offer
Hazard Light Switch + Race-Car-Driver / Nanny-Driver Toggle Switches for Auto Trans.
$Free if you buy something else
Roof Light Switch
No Plug / Loom
$5
Fan Speed Control Switch
Pulled From C33 Laurel Wreck. Comes with plug and modified wiring
$5
Cefiro Side Mirror Controls, Fog Light Switch + Trim Piece.
$30
Another weird box thing.
$5
Rear Windshield Demister Switch.
$5
A31 / C33 Clear Front Indicators.
$60
J60 Purple Label Air Flow Meter.
w/ Plug + approx. 100mm – 150mm wiring.
$25
Prices are exclusive of shipping.
Located Perth, WA
https://www.sau.com.au/forums/topic/372970-epic-for-sale-thread/
  • 4 weeks later...
  • 3 weeks later...
  • 1 month later...
    • It's kind of interesting - They definitely do builds that split the difference between what they like and what will generate views and engagement. The NC Platform always surprises everyone in a good way, in an uncomfortably good way some may say. They could throw a LS in there and arguably have the best (and best performing) car of the entire stable. But that isn't necessarily what draws views, because people viewing don't want to accept the vegetables of a LS NC MX5 being a superior vehicle in every way (including fun) than a RB26 240Z. This is also why there's not a lot of content about the GR Yaris (on the web in general). They're too good, yet 'only a Yaris' The community doesn't want certain cars to be as good as they are - to beat their hero cars, and I believe the NC MX5 is absolutely one of those cars.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
