Hi Guys,
R33 GTST S2 w/ A-LSD
Full exhaust (High Flow 100 cell Cat was installed 2 days before the problem first appeared)
R34 SMIC (Installed last weekend)
Last week (Thursday) I went and got petrol at the servo and when I turned my car back on, the HICAS Light was on and the steering was very heavy (still drivable though).
I turned the car off, waited 10 seconds and turned it back on,
Light was still on, Steering still heavy.
I drove it home (2km) then turned it off, waited 30 seconds. Still bad.
I went inside and got my Consult Cable / ECUTalk Display and went back outside to plug it in 30 minutes later.
When I started it up it was working perfectally again, No Light, Power Steering working.
ECUTalk displayed No Fault codes on this or previous starts.
All was fine for a week, did 350km on it and then last night went to get Petrol.
Same Servo, after the same 40 minutes of peakhour.
Filled up my tank with another 45L of V-Power and started it up. Once again, Hicas Light on and no Power Steering. No Fault Codes.
Drove it home and just before I turned into my driveway (2km) it magically fixed itself and the Hicas light went off and power steering returned.
Random Questions:
Any ideas what I should check or what might be causing this?
Is Fuel in any way related to HICAS?
Is HICAS in any way related to Power Steering?
Maybe a sudden temperature difference when I add in 45L of cold fuel to the warm car?
Anyone else had this issue?
Heading up to DECA in 3 weeks but don't want to be trashing around a car with HICAS or Steering issues, obviously.
Thoughts?
Cheers,
Simon
https://www.sau.com.au/forums/topic/372993-hicas-light-no-power-steer/
Hmmmmmm....
I've been reading through all the other Hicas related threads on here and a lot of them seem to have this problem.
There were mentions of bad battery earth (mine does need replacing badly, I had to remove it a few months ago for a little bit to get a new battery in, and ever since then my stereo has a bad earth whine to it...)
I will try HICAS Diagnostics as well and report back.
Otherwise, looks like it might be time for a lock bar :P
  • 3 weeks later...
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
