microtech are not as bad as everyone says. its just harder to get working on a rb. very easy to tune but very hard to wire into a rb. alot of people use the plug and play adaptor for rb25s hard wire it in properly and its fine a bit of a hastle to wire in but once done its worth it.
like i said before if the microtech was not given to me i would have gone a nistune or PFC
The model number implies its drivers, normally halved.
An LT12 can do 12 cylinders batch fire or 6 sequential.
Correct me if I'm wrong anyone..
I know its meant to be sequential but the last LTX12 I scoped definately wasn't sequential - that was using a 36-1 inductive trigger and factory inductive cam trigger on a 2/1JZ. Apparently microtech's cant use too higher tooth counts and which means on an RB they are most likely only using the 6-5-4-3-2-1 signal not both the 6-5-4-3-2-1 and 360 tooth signal like the factory/PFC do.
Hence why there is very few ECU's that I trust to use the OEM RB CAS for stable igntion control.
i've had microtech's on a few cars now, I think they serve their purpose, cheap to tune & simple, very broad in load points for tuning, best suited for drag cars and rotors. but if u don't mind turning the key a few times on cold days & warming it up for 5 mins then microtech will be just fine
if you don't ever plan to pass a emissions test, and you don't care about the microtech's timing drifts and you can be bothered with aftermarket aux's then go for it.
its just not the right way of doing things.
How well do they work as a piggy back?
I've an auto & I'm looking at a possible high flow turbo in the near future (nothing major, only aiming for about 220 - 230rwkw) & I'm a bit stuck on ECU choice.
Since no stand along aftermarket ECU works properly with a R33 auto (as far as I know from reading old threads), & some old suggestions was running a combo of SAFC + STIC, however the latter is nimpossiblebile to find. The other one was to run a Emanage Ultimate, but I found most tuners around my area dislike them for some reason, so no point getting it if I can't get a decent tune out of it.
I talked to my tuner about the issue & he reckons a micro tech wired in piggy back would do fine with a stock high flow.
Any opinions on this?
Edited by Mayuri Krab
Can you explain in more detail?
I thought the harsh changes where due to replacing stock ECU which backs off timing before auto changes gear with a stand-alone aftermarket one, which doesn't do that.
But since you retain the stock ECU wouldn't that mean this 'back off timing function' is kept as well?
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
