  • Replies 43
I bought the 5in Venom cat and had it welded in (no flanges) as I am not planning to remove it. I have a 3in system looking for about 300 -330kw from my RB30. We need a cat for low volume certification these days but the certifiers do not do comprehensive exhaust gas analysis - I suspect these 100 cell metal cats would not pass - would be interested if anyone has been through a test with one.
whats the point in spending all that money and running a high flow cat if it doesnt meet emissions? seriously, just bolt in a standard cat when you have an inspection then spend $50 and get a decat.
recon a minimum of 300 cells for emmissions and get it as close to the turbo as possible, can change it to a 100 cell if you want when you get your certificate for the engine
+1
The point is to avoid a $10k fine if you get caught without a cat at all. Compared to a $200 outlay of a 100cell hiflow cat that will provide almost no restriction. You cannot get a fine for having a cat that probably wont meet emissions standards (100 cell cat).
i dont have a stock system and its on a vl so the whole exhaust is custom made
It all depends on the impact of you failing. If it costs nothing and you can go again later sure try the hiflow cat but if it costs you or you failing causes you to loose rego then you should definitely fit a 300 cell cat and then change afterwards.
Show me proof that anyone here or elsewhere in AU has been fined the full amount of 10K for not running a cat converter.
Pete was stating that its better to run a std cat than a high flow - which probably wont pass.
Why run the risk of a fine for no cat?? To save $200 and 2-3kw?
Yes I also have said multiple times in this thread to run a standard cat to pass the emissions test. I was suggesting changing to a hiflow 100 cell cat after the emissions test.
exactly, its just a waste of money. the only way youre gonna get fined for not having a cat is if youre stupid enough to go through an inspection without one
You may not be aware but in Sydney they often have defect stations. Little outposts setup by police where police will pull import cars and other cars on the street into these stations, put them on a hoist and defect everything not standard.
im not sure what your point is? Again, pete's reply was that a highflow is a waste of money, as it would fail the epa test and if you went through an inspection without a cat, then expect a fine.
Here in SA, you only need the one defect to be sent for a full inspection (can be a few things like noise etc) and then fined just for being defected
I don't think you understood what I meant. These are EPA setup stations. Police bring in drivers, EPA pulls out the book for your car and gets you down for everything not standard. You will cop a fine for running a cat not meeting standards, not a fine for running NO CAT at all. That is the difference. Its a grey area. They have hoists to get cars up. Ive seen one setup on james ruse drive near rose hill. Not a pretty site.
I don't think we have them in WA, the only Police setup stations I've seen are your typical RBT buses & drug test.
Also from watching some old news, you guys also have some kind of special Police task force who's solo purpose is to pull cars (mostly imports) over & defect them, I think they are called operation Tapan or something?
Again we don't seem to have those in WA (thank god!)
dont count on it being that way for much longer. . .usually what happens in the east makes it way here to W.A (aka Wait Awhile) eventually
it's all good arguing about this on a internet forum but know one here can give you a straight answer (or at least the one you're looking for) so email venom an see what they say. :thumbsup:
good luck to you sir :)
george told me my best bet would be a factory BF xr6turbo cat for the emissions test. then change it over down the track.however after talkignt o him a bit more any 200cell plus cat should do the job as long as its ceramic. so im thinking going the catco ceramic cat and then putting my decat back in after the test.
I understand you now, drive around with a decat pipe, if you get pulled over and cop a defect then put a factory cat back in when you go in for an inspection.
What about this scenario:
Car accident where the car is undriveable and the insurance people come and do an inspection of the car. They could argue that your car is not roadworthy and therefore not covered by insurance.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
