Don't you have an HKS tuner over there?
HKS Fcon iS will do (at least) as much as the eManage Ultimate and can be picked up pretty cheap (have seen them on eBay for $300-350).
Problem is that the ECU will still try to tune around it.
On the plus side, the ECU will also accommodate and self tune for basic mods such as exhaust, runner spacer and suction pipe (although the SP will max out the AFM)
Ok.
Just spoke to another tuning house, to my knowledge the only one that does Fcon tuning in W.A.
He's confident with the whole thing, he seemed to know a lot about our ecu (except he though 19 psi was way too high on stock turbo. He said 1 bar but I thought that was stock )
F-con IS inc harness $1500, $700 tune. Total $2200
Full TBE HSK twin/dual I think he said? $1300 fitted
HKS boost controller $500 fitted
Suction pipe and time to do throttle wire cut mod not quoted.
Perhaps this is a better way to go as no one will do an emanage and I'm not confident with any other system besides Fcon at the moment?
He did say that if I want larger injectors/turbo we'd need to go the Fcon pro but it gets expensive.
$2500 fitted inc harness, $2000 tuning time
Edited by ArdentEagle
  • Replies 151
HKS do a plug in harness for the F0con, so I'm not sure you need to pay extra to fit it.
Hunt around, get one cheaper, then get him to tune it? Tuning cost doesn't seem excessive IMHO, but $1500 for the F-con IS seems astronomical compared to the $300 Cam quoted.
Ok.
What?
Fcon iS can definitely handle larger injectors. It is a very comprehensive piggyback... but in the end it IS a piggyback.
The Fcon V-Pro will be better suited to our tricky ECU's.
You might want to make sure he can actually get hold of a VQ25det Fcon harness (NP5-15) first.
They are a discontinued item and from what I have been told HKS have no intention of making up any more... hence discontinued.
They ain't cheap either, mine set me back around the $420 mark... but they are farkin serious compared to the eManage universal harness.
So $1500 for a harness and brand new Fcon iS still high although as an HKS dealer, they'd have to put their margin on top of the normal price.
You could always try Jesse Streeter or RHDJapan to see if you can get both cheaper, but I'm sure you could get an iS over here for pretty cheap.
Also, you might want to check which EVC (boost controller) it is for $500.
lol... just noticed... Twin Dual turbo back exhaust?
I have a feeling he is thinking of another car/engine.
Has he seen your car and engine (without cover)?
Make sure he is not thinking of either a C34 Stagea (RB25det) or the VQ35de engine (350z/V35 etc)
Or they are not an authorized reseller so can not make a profit..
And HOW!
What?
And HOW!
He did specify the VQ25DET so I hope he got all the parts right. He said that he had one harness left in stock in his shop. It looks as though I'd be better off buying the Fcon elsewhere and buying the harness from him. He was reading from something under NM35 stagea when he recommended that exhaust but I'm not exactly sure what brand it was :-/
Otherwise should I go elsewhere for the exhaust or just get him to get the legalis? Does that come as a full kit or do I still need a custom dump?
So if I want to upgrade injectors and turbo at a later stage id Fcon IS will still handle it? Damn I wish I knew more about mechanics so I'm able to articulate myself better when speaking to the tuners.
If the VQ25det harness is the NP5-15 and you want to go an HKS ecu, I'd say grab it as it is one of the few left... anywhere.
Dunno about a True Dual exhaust for VQ25det. We have a single exhaust due to a single turbo and it is certainly a crap load of work to put dual mufflers since the ATTESSA pump's cradle is where the driver's side muffler would go.
Any of the Jap exhausts are cat-back only, although I think that Garage Maki do a full exhaust (or did).
Fujitsubo Legalis, Nismo (76mm version), Kakimoto R or Blitz NUR are the pick of Jap branded exhausts IMO, but they are all cat-back so you'd need a dump and front pipe/cat made up to suit.
CLICK HERE for a list I made up a couple of years ago and is missing a few units, but you get the idea.
Of course the iS will cope with larger injectors. You'll just need a retune when you go larger... as you would with an eManage Ultimate.
For reference, there is a 3.6L VQ25det Stagea in Japan putting out 450awps running a re-flashed ECU (mainly to play with the cam timing and remove speed limiter) and an Fcon iS... so I'd say it was capable.
My preference is the V-Pro (version 3.2 or 3.24 only) over the iS, but the iS will be fine.
When I asked Streeter about the Fcon V Pro harnesses for the VQ25DET he said had access to stock....about $400 delivered I think.
If your really keen on going HKS there's a 3.3 on IM:
http://www.importmonster.com.au/view?url=http://page10.auctions.yahoo.co.jp/jp/auction/m86845788&thumb=http://f3.auctions.c.yimg.jp/img319.auctions.yahoo.co.jp/users/4/2/5/2/maxpower1115-thumb-1312634529559006.jpg&title=fcon
Sorry if anyone here is bidding on it...:pirate:
Edited by ironpaw
http://www.importmon....jpg&title=fcon
Bloody great buy. I think I'll go the IS at the moment. ( bound to regret this ) as I'll end up over budget at this time because no doubt I'll want the whole hog now. I can afford 5k but not 9kangry.gif - I'd spend every last cent I have otherwise.
Think I'll be settling with a prompt 200awkw car rather than a 250+monster
I appreciate the effort and thought you've gone to mate.
I like the sound of $300-$500 Fcon IS as mentioned above.... If I can find one.
Interesting, when was this?
Pretty cheap iS (just chuck or sell the harness)
http://www.importmonster.com.au/view?url=http://page13.auctions.yahoo.co.jp/jp/auction/r80660785&thumb=http://f6.auctions.c.yimg.jp/img333.auctions.yahoo.co.jp/users/4/2/5/2/maxpower1115-thumb-1312633984538597.jpg&title=
Cheap V-Pro... IF it actually is a 3.3 (serial should be 30000 or higher)
EDIT: just noticed that is the same V-Pro that Jethro linked to. Good buy if the seller will confirm the serial. As a note, you need any V-Pro with the serial higher than 200001 (v3.2 or higher)
Edited by iamhe77
http://www.importmon...8597.jpg&title=
http://www.importmon...9006.jpg&title=
Thanks for finding this for me.
I've never used this site before. I presume if I loose out on the bid my account is re-credited or am I obliged to spend the deposited $$ there?
I've never used this site before. I presume if I loose out on the bid my account is re-credited or am I obliged to spend the deposited $ there?
If you dont win the auction you dont pay anything thumbsup.gif the funds will stay with IM, however you can ask them to transfer it back to you after the auction has ended
Or you can just contact Jesse Streeter and ask him to bid for you. Easier because he does everything, and seems cheaper too.
I think I'll take this option....just to make sure I don't F anything up. Fcon IS shouldn't be too hard though, unless I need a particular serial#
Is he the best option for the exhaust too?
Ryan, the Dolphin intake doesn't replace the lower restrictive part of the intake only the rubber part afaik.
I think the stock injectors, suction pipe, cooler etc will allow perhaps 190kw on 98. Any more and there are big changes to be made.
what are these changes???
for say 250-300KW@W
for say 250-300KW@W
Injectors, Fuel pump, Intercooler, 3 inch intake, full 3 inch free exhaust, Map sensor, standalone engine management (V PRO, PS2000), Large frame turbo, Built gearbox, the list goes on... While you can do over 250 on petrol on the highflow/emanage it isn't a safe tune and ethanol is required imo.
Isn't Aaron running close to 300 on 98?
What do you think you'd need to make over 250 safe on 98? V Pro and cable throttle?
    • Unfortunately,  it feels like it's been on the decline for nearly a decade. Especially as wallet racing became popular with them(biggest wallet can pay off a car that wins). It seems like a different mindset kf ownership these days. But, hopefully people like yourself keep some of the skyline scene alive.
    • A bit of data is always good, beats the Facebook experts with their opinions Although the kWs aren't anywhere near what you are after, it should give you a good indication. I have Bosch 1480cc injectors, often called 1650cc (only when run at 4bar). I run mine at 3bar base so I don't thrash the fuel system. Up top, making 437kW with boost dropping, injector duty is at 69% on E80 (might have had some residual 98RON in there)
    • I have some downtime due to winter, and just wrapped up converting the car over to flex fuel. We don't get E85 at the pump over here in Canada, but I will be running Ignite E90 Race gas. I'll be mixing it with 99-100 RON pump gas and shoot for 50% ethanol content, up to possibly 85% content if there's any noticeable gains. Here's the question. Most I'll ever want to hit is ~600rwkW. I've currently running 1200cc injectors and want to keep them under 90% duty cycle. As per some online injector calculators, I should be good with 1200's well past 600rwkw on E85. As per other calculators, I'll need 1600-2000cc's. The variety is rather amusing.  With you Australians having E85 at the pump, what realistic duty cycles are you seeing in those kW ranges on E50 & E85 on your injectors? Thanks,
    • No issues here with my PRP gears in an OEM pump housing. I did confirm all housing clearances were to spec prior though. Cheers.
    • Thread is a bit old but figured id give my input anyway just incase. Have had lots of water problems in my R32 and was getting sick of wet tools in the boot and water filling up half my taillights. I ended up finding that whenever my car had been repainted they didn't reseal the taillights to the body of the car so water was just flowing straight into the boot, this is amplified by all the water around the bootlid being directed down to the taillights so would get pretty wet whenever I washed the car or it rained. You could probably use silicone to seal them to the body but I think from factory they use a roll of automotive grade butyl rubber. Hopefully this helps you if that ends up being how the water is getting in on your car!
