  • Replies 151
What do you think you'd need to make over 250 safe on 98? V Pro and cable throttle?
Why would you need a cable throttle?
A "safe" 250 can be done on 98 with highflow, intake, intercooler, exhaust, injectors, pump and a eManage Ultimate
I don't think the emanage is reliable above 250, the timing doesn't hold steady at all with the stock ecu still in charge causing pinking occasionally. With ethanol it won't obviously, that's why I run it now.
He was because he wanted better response and the eManage can't get around the ecu f**king with the throttle.
Hence the thought to remove the FBW throttle body, leave the ECU in limp and control it all with the eManage.
To much of a f**k around, hence the change to the Fcon V-Pro.
At least, that's my understanding (or lack thereof)
Interesting.
Has Craig found this to be an issue?
Of course, but his went rich also.
There is a noticeable timing change on high boost at different times without additives.......advance/retard under hard acceleration ........but then again I still have to go back on the dyno as I have changed a couple of things since the tune.
as far as being safe......motor doesn't sound or feel stressed so yeh it's safe....but I only run 15-16psi most of the time!.....If I am running 20PSI I now run Octane boost in it and all seems good.
P.S. And yes my car does run rich!
Edited by Jetwreck
Advanced timing is ok if its run rich, that's how the Japanese tunes run most of the time. As long as theres no knock you're fine. The hassle is you need to run a buffer of a few degrees at least as the stock ecu changes constantly. That's why I'm going standalone.
I'm looking at getting my exhaust done next week. Is it advisable to get the suction pipe done at the same time or should I wait until I have the Fcon IS installed?
As you can tell I know nothing about mechanics.
Edited by ArdentEagle
Wait. Without some method of tuning, it will run like crap (in a bad way, lol).
Only if you floor it a lot.
I've been running the suction pipe with stock ecu/injectors/pump for... erm... a while.
Unless I put my foot to the floor, it runs very nicely.
1/2 to 2/3 throttle is fine on my car
Impressive. That's different to my (short) experience so far. Mine only ran "ok" for the first drive on a cool night, with very minor AFM adjustments. Since then (in warmer daytime running) I've had to baby it whilst slowly making changes to the tune. Just haven't had enough time to get on top of it as yet.
Going by my almost useless "memory", your AFM is on the verge of a bend though, yes? Could this be the issue?
The air is more dense on the outside of the bend and gets more so the faster it flows, it makes it very hard to tune around, even with an emanage...
It certainly could be an issue. If it turns out to be "untunable", I will put the standard one back on. Other than an extra little hole in the airbox (which is easily patched) I made sure I didn't mod any other OEM part.
And if it does turn out to be untunable, I might be tempted to ask "why didn't someone mention this before" lol.
Mmmm, if I give it some more thought I might be able to block off the AFM hole & move the little housing thingy down the intake to a straighter bit.
Anyway, I have about 200 voltage load points I can set (either up or down) so I reckon I have a fair to reasonble shot at getting it right. It could just take a whole lot of time....
I did warn you. :)
Haha, I don't remember. But I'm not sunk, just some work to do to tune it. Anyway, nothings lost. All this stuff is just a bit of fun (challenge?) for me. Works / doesn't work - either way no big deal :)
    • Yep it's an r34. Usually people remove struts without removing the front upper control arm (fuca is what i assume this is?) So not sure why mine wouldn't fit. I know on my other car I did a similar job and it wouldn't fit until I removes the ball joint nut even though I didn't remove it prior.   The upper arm doesn't seem to be in the way (the part that's bolted to the chassis. The part that's bolted onto the j arm I'll check that out though.   I was going to compress the spring and put it in with the compressor attached but not sure if it will work  Haven't seen anyone do it.
    • I have a small lip on the boot of the E90 and I've been toying with the idea of trying to mould it in to the boot to remove the gaps. I guess shaving the seams? No idea what the terminology is here.  What I'm wondering is, if it's current double sided taped down, what would I do to more permanently attach it so it makes a good base for the filler? It only has edges so no way to bolt it down unless I add some braces. I've done a lot of fibre glassing in my time so that's nice and easy but I'm not sure what my options are here.  Sorry, this is the best pic I have and I'm 4 million ks from home ATM.
    • Based on this comment I went googling. A052's in the sizes I want are certainly not cheap, but I couldn't find anything in the V70A anywhere. How much do they run/where do they get sourced from? From what I know (nothing but internet searches and reviews etc) the R888 has pretty much fallen off from anyone's actual use, and the AO52 is the king of "road legal" rubber. Nobody is driving around on their daily for Z221, AO050, DZ03G. At that point, for purely track only tyres - Why not buy actual slicks? Why does nobody actually do that anyway?
    • This an R34? It shouldn't matter though - it should be the same as on any of the others, and by "any of the others" I mean R32, because that is the car that I have had the front end apart on about 50 times this year. Sometimes, it is much easier to get the lower shock eye onto that pin when: a) you have the upper shock nuts backed off a few turns so you can wiggle it a bit more freely. When they are tight the bottom of the strut is much harder to move that _leeeetle_ bit you might need it to to win the fight. b) you have the outer bolt(s) from the FUCA out and so you can move the lower pin around freely too. Then, all you have to do is put the upper arm back on when you've got the rest back together, and this is where jacking under the balljoint can help.
    • One question before I make a bigger mess potentially, do I need to undo the nut on the outer ball joint?
