M35 Mod "path"
Autotainment in Burswood did mine many years ago. But they have now moved to Vic park
Total miss. Just had to take back the water pump. Wrong part, it was for the older V series. Typical Nissan service/dealership 🙄
Not directly. I mean, there's nothing about what is happening at the wastegate itself that will generate smoke right there. But....if the car is overboosting and the ECU is dumping in fuel (because that's what they do from factory) then, yes, black smoke will result. It will also smoke if it is pinging its tits off too.
Can a jammed actuator cause black smoke on boost somehow?
Yeah, whenever I say "HP", I mean HP. As in, at the engine. Allowing for a 25% discount from engine to typical Ozzie braked roller dyno figures, then subtracting the usual (more optimistic) US inertia dyno offset..... you get into the 600 actual engine HP territory from your 484 wheel number. 484 / 0.75 = 645 (that's Aussie rw intertia HP, converting to approximate engine HP. 645 --> 600 is discount for inertia dyno. Could actually be worse than that. But that would still be up around 600. So near enough for purposes.
