M35 Mod "path"
Hi Dose, I know you'll be reading this thread. Brake pads are going good mate thanks. Anyway, pulled the 33 fuel tank out today because we were limited to a disgusting 480hp on the old fuel pump setup. On pulling the tank, I found the cracks in the photo (I don't think they're leaking, but fuel evaporates quick so hard to tell). What's the best way to repair, or is their a new tank alternative? Thank you.
By MidnightR32 · Posted
Update on the car... I took video of about 9 minutes of it running, shortly after start up, and the car sounds OK? I replaced the ATS and confirmed that the new/old one are showing warming than freezing teamptures. I will replace the wideband tomorrow, but maybe this video can give some insight. Logs of warmup - https://drive.google.com/file/d/1bpvfmsLfZEjg_rBZw8IseAuM3iWq3BGN/view?usp=sharing -
It's easy to tap to the other CAN networks, and in addition, most of the stuff you'd want could be obtained by querying the data over UDS on the network available on the OBD2 port. That said, it's much nicer to just listen on the appropriate network to data that's being streamed rather than querying in steps using OBD2 or UDS.
So it's even worse than I thought. I may have to source something that still has stock parts. Thanks for the replies, Gents. Plenty of food for thought.
