Parts for sale in Adelaide SA
- r33 gtst Rubber intake pipe with oil breather apparatus $35
- r33 gtst Stock dump pipe $20
- r33 gtst Stock dump & front pipe $30
- r33 gtst Oxygen sensor $40
- r33 gtst Air Con fan $35
- r33 gtst Stock Intercooler + Pipes $65
- r33 gtst Series 2 coil pack loom $40
- r33 gtst Alternator $60
- r33 gtst 2nd hand water pump works fine $35
- r33 gtst Timing belt $30
- r33 gtst Bosch Air con, power steering, alternator belts brand new $70
- Garrett Adjustable Actuator with bracket 15psi ( New) $70
post-31991-0-43981800-1312510347_thumb.jpgpost-31991-0-48114400-1312510372_thumb.jpgpost-31991-0-57871000-1312510394_thumb.jpgpost-31991-0-27420500-1312510399_thumb.jpgpost-31991-0-17147800-1312510423_thumb.jpgpost-31991-0-85723300-1312510427_thumb.jpgpost-31991-0-29474000-1312510483_thumb.jpg
Updates remaning items with price drops:
- r33 gtst Stock dump pipe $15
- r33 gtst Stock dump & front pipe $20
- r33 gtst Oxygen sensor $35
- r33 gtst Air Con fan $30
- r33 gtst Stock Intercooler + Pipes $60
- r33 gtst Alternator $50
- r33 gtst 2nd hand water pump works fine $30
- r33 gtst Timing belt $25
- r32 rb20det & R33 rb25det exhaust manifold gasket kit new $65
Cheers
Updates remaining items with price drops:
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
