  • Replies 114
Damn Exterminatus is intense!
It is especially difficult when you are on your own! I played it last night with 3 other people and it was relatively easy, was going for about 45 minutes when I had to purposely do foolish things to die so I could go to bed. would be interesting to see how much worse it got when I have the time to play it until I die for real!
I have developed a new found respect for the Plasma Cannon.
We were on the last couple of waves of the escape mission and every team member kept getting overwhelmed with orks, but they started to realise that all they had to do was keep them all off me and i could hose them all off with the charged shot.
It is so satisfying to see an entire horde just disappear under the bright blue flash banana.gif
Me too, Its all I have been rocking lately, even if you get ganged up on just STOMP then run off charging your cannon then hit your persuers in the face with that lovely blue ball. The plasma gun is very good too if you are running tactical.
So who else is hating the new update to multiplayer?
Tactical marines are now worthless and assault are nearly unstoppable....
Before i could easily take out an assault marine if i saw him soon enough, i would pump a few bolter rounds into his head, then drop a grenade at my feet and roll away then shoot him as he lands, easy.
Now i have half as many grenades to use, which take twice as long to throw and if you roll backwards you are essentially frozen on the spot for about half a second as you watch the chainsword swing towards your head.
I even get the added bonus of watching an assault marine run towards me for a good 10 seconds as i pump bolter rounds into him, only for him to get into close quarters and cut me to pieces in 2 swings of his chainsword.
Until they fix this bullshit, i'm not going to bother playing any more.
Edited by Chappy
what new update?
They have changed the rules for multiplayer.
All people now start win 1 grenade instead of 2. Favour of the armory gives you 2 instead of 4.
It takes longer to throw a grenade and there is more of a pause between when a tactical marine rolls and when they are allowed to do anything (shoot, throw grenade, roll again etc).
I could also swear that they have made assault marines tougher.
And i have noticed significantly more lag in games since the update.
thats bad, I had horrific lag as it was. Completed level 20 of exterminatus yesterday....only to get swamped my Chaos Space Marines, I really thought I had finished and was not at all ready!
    • Nothing wears "the most". Different cars will always show signs in a different place. 114000 km is either nothing at all (as in, given the calendar age, nearly brand new) or it's completely unbelievable. We stopped believing numbers like that about 15 years ago. Having said that, my car is up around 270000 km and I have put bushes into some places** as many as 10 times in >25 years that I've owned it. ** FUCAs, which are different on an R32 than on a 33, so not likely to be the same issue for you. I have original ball joints all the way around. They are perfectly fine. Same with the spindle bearings in the front. Tie rod ends have all been done at least once though. Pretty much every other bush in the car has been done at least twice. Some of those in the first 100000km after I got it (which was at a genuine 23000!). Some of those bushes are now sphericals, and they are on a <cough> regular maintenance schedule, hence why my FUCAs have been rebuilt so many times. Half of those 10 in the count above would be in the last few years! 'twere I you, I would budget on replacing everything, for fun and prevention. If they really are 30 year old rubber, they will all be unpleasantly aged in one way or another. Whether that's corrosion of shells, or the rubber cracking, or sagging under the load, etc etc.
    • Tighten until it starts to get loose again, then back off 1/4 turn?
    • Do them as you'll find when you remove them they are perished/dried.    Its probably one of the best things to do as makes the car so much more responsive. Do ball joints while there too.
    • Hi All Got an R33, about 114,000km on the clock.  Handles very nice, no signs of issues.    Engine is out and i'm doing an underbody refresh, mainly painting subframe, cosmetics etc. Can't see anything physically giving play, but I'm wondering which bushes are the ones that wear the most, or the first ones that may give problems down the track? For good measure I'm thinking to fit new ones. Thanks
    • This post has OUTER tie rod torque spec - what about INNER tie rod torque spec??? Cannot find this info ANYWHERE.
