The shift times are only half affected by the valve body, the auto controller is very slow in sending the signal to the VB and sends a ramped voltage, especially to the lock up clutch. Opening the valve body does make it quicker and firmer once the voltage is there and allows more pressure to be run if needed but it wont make the shifts instant when you hit the switch.
I don't think mine has that much of a pressure increase from stock as the extra clutches allow sufficient torque transfer at the moment.
  • Replies 183
I went for a ride in Aarons, but didn't get to drive. It felt a lot better than mine, but I'd imagine it'd feel even better when you're driving.
I'd be interested to see how the Trans Go version compares to the RVO version Aaron has. I think the RVO one was cheaper too wasn't it?
From memory it will be about the same price depending on how much I get the Kit's for and depending on what deal you get from RVO.....I nearly did the RVO but I changed my mind as I preferred the Transgo spec!
Either kit is fine though....Aaron and Jethro are quite happy with theres and they are putting out good numbers.
the only comparison I have is with scotss. but his is a built box, so its very different.
If Aarons kit is just upping the pressure I would assume that could limit the life and reliability of the trans, unless the pressure hasn't been lifted too much but then it might not get the desired results. Its definitely better to go a modified valve body than just upping the line pressure. From what I know thumbsup.gif
a shift kit isnt just upping the pressure. its a shift kit.
Rvo make their own kit with a spinning lathe and other tools. which is why its alot cheaper than the transgo
this.
people will prefer trango for the name, and back up they get from the public. If i didnt find RVO(and didnt wanna be a test mule) I would have gotten a transgo kit.
but as said, Jethro and myself are happy with the RVO kit.
How much cheaper?
can you tell us what RVO do to make the shift kit work....and I'm not being a smart arse.
guy's below is a short read for you....just so that you know why the shift kit is important when you do start winding up the power......no pun intended with the Transgo site either!
http://www.txchange.com/transgo.htm
How much cheaper?
ill give em a call and find out exactly what they do.
but when i was looking for transgo shiftkit installs at the time I was doing it, the cheapest quote i got was something like $850 where as RVO virtually halved the price so yeh give me ten minutes lol
I know what you are talking about with the pricing....I got quoted a supply and fit for the Transgo from my gearbox place of $850.
Kit in Australia(And he has dropped his price $150 from last weekdry.gif) : http://www.ebay.com....c#ht_2769wt_907
Kit out of the US: http://www.ebay.com....b#ht_1336wt_907
Edited by Jetwreck
yeh i think the Aus one is what i found when i was doing mine. but if you guys prove the transgo to be the goods, and i decide to keep the stag, i might convert
Whats the diff between the US one and the one from your OP? Why is there a price difference (not having a go - just curious)
You spending cash for no reason again Aaron? :rolleyes:
if i keep the car. might as well
there is no difference, which is his point lol
i thought we were talking about this.
Hmmm, let me see. $320 or thereabouts for a transgo kit delivered from the US- takes about a week to WA.
Or $650 for a transgo kit delivered from over east- takes about a week and a half usually....
So, save myself over $300 and get it quicker? Decisions decisions....
Story of our lives. When I converted my arx to a normal stereo after the bose stuffed up, I needed a standalone AC controller board. $550ish from Nissan here- and they'd have to order it in. OR less than $200 delivered from a dealer in the US and it arrived within a week. Unfortunately companies set their prices per country according to sales volume- we simply don't have the volume here to compete price-wise with internet sales from the US.
Jethro can correct me if I'm wrong, but I think is point was why is there a price difference between the US ebay one and the one in the OP. There's probably a very good reason for this that I have no idea about... something missing no doubt.
    • A bit of data is always good, beats the Facebook experts with their opinions I have Bosch 1480cc injectors, often called 1650cc (only when run at 4bar). I run mine at 3bar base so I don't thrash the fuel system. Up top, making 437kW with boost dropping, injector duty is at 69% on E80 (might have had some residual 98RON in there)
    • I have some downtime due to winter, and just wrapped up converting the car over to flex fuel. We don't get E85 at the pump over here in Canada, but I will be running Ignite E90 Race gas. I'll be mixing it with 99-100 RON pump gas and shoot for 50% ethanol content, up to possibly 85% content if there's any noticeable gains. Here's the question. Most I'll ever want to hit is ~600rwkW. I've currently running 1200cc injectors and want to keep them under 90% duty cycle. As per some online injector calculators, I should be good with 1200's well past 600rwkw on E85. As per other calculators, I'll need 1600-2000cc's. The variety is rather amusing.  With you Australians having E85 at the pump, what realistic duty cycles are you seeing in those kW ranges on E50 & E85 on your injectors? Thanks,
    • No issues here with my PRP gears in an OEM pump housing. I did confirm all housing clearances were to spec prior though. Cheers.
    • Thread is a bit old but figured id give my input anyway just incase. Have had lots of water problems in my R32 and was getting sick of wet tools in the boot and water filling up half my taillights. I ended up finding that whenever my car had been repainted they didn't reseal the taillights to the body of the car so water was just flowing straight into the boot, this is amplified by all the water around the bootlid being directed down to the taillights so would get pretty wet whenever I washed the car or it rained. You could probably use silicone to seal them to the body but I think from factory they use a roll of automotive grade butyl rubber. Hopefully this helps you if that ends up being how the water is getting in on your car!
    • Correct And whatever you do, don't use an oil pump gear, especially the one that starts with the same letter as Santa and the last letter ends with the same first letter as Lagoon. Get a proper oil pump, like a Nitto, Tomei, etc. and make sure you invest in a big fk off sump. Won't go into too much detail, but I am sure it caused my previous built motor to go bang.
