  • Replies 183
Yeah I'll have to do a ring around tomorrow. So many decent deals on stuff at the moment, just a lack of funds and knowledge on the M35s!
or just take your car off the road for about 4 day's and send me up the VB!
bet you I still work out a lot cheaper!
Hey Craig can you still do a change over unit?
I can...but have had a rethink on it.
In other words I would prefer not to as I would want to test the exchange units in my car before sending out......this would be a bit of a PITA!...e.g If someone had a bad Solenoid in there VB and didn't tell me the next person to do an exchange would get a bad solenoid and would be pretty pissed about it. I need to think up some kind of a system where this wont happen!....at the moment I have no ideas but am willing to discuss.
I'd be looking into an Express Post box; that way you're getting back the same VB you sent; even mark the VB & solenoids before you ship if you're worried.
Just depends on turnaround time; Express Post to SA seems to be around 2-3 days; also, you can track the package. It's not hugely expensive, (VB weighs 4-5 kgs) and insurance (loss or damage) for $650 is $15.
A courier service might be quicker; less down time.
Food for thought.
I'm willing to use my company's TNT account and that is overnight but I need to pickup and deliver from an address that is manned from the hours of 8AM to 5PM....we can just add it onto the bill....would be about about $20 each way from what I charge you.
PM me for further detail if you want please....or ring me!
Express Post should be overnight Sydney to Adelaide normally?
That's a pretty good idea Dale, would think it would work out well for most people.
When I send Sway Bars; it takes 3-4 longer to get to SA than delivery to WA.
Weird...
That was weird Dale, but those sway bars were heaps heavier, and a very odd shape.
Usually when I post express it's overnight to anywhere in the network.
I think Express Post for 4-5kgs would be pretty close to the $20 for TNT.
When I post link kits; I normally do Express Post (it's cheap, and has tracking) and Auspost won't guarantee next day to WA, SA and North Queensland.
The TNT option definitely sounds like the go.:thumbsup:
looking forward to a weeks break on this now as the next 4 kits wont be hear for a week.....I recounted....thats 7 NM35's and 1 PM35 I have done.......4 since Wednesday.
On other news guy's if you want kits I am after another 2 to add to the next buy.....to keep shipping costs down.
guys.....no takers on this....will be the last buy for a while.
Is it worth doing on a stock car?
Do you mean totally stock? As in nothing changed at all?
Dale's car is still stock turbo but with exhaust and handling mods and he found a big improvement.
I can not advise against my car as it is far from stock but I am very happy with the result.
Cheers
Andy
Yeah, Definitely.
Cheers
Andy
Spot on Andy; the difference is simply a night and day improvement. I have nothing but good things to say about the shift kit.
Absolutely no downside with regard to normal light throttle driving, and when you want a solid shift; you've got it. Honestly; this is the way the car SHOULD be.
As both you & Craig have said; the difference is just compounded when you are dealing with greater than stock power levels.
Cheers, Dale.
It's been 4 days now since Craig (Jetwreck) did the work on putting the Transgo components in the VB part of the gearbox. What a difference it makes!!!!
Though, it the kit isn't much to look at for your money, it's worth every cent.
As Daleo said in his posting, the transformation is stunning. No more backing off when gear changes occurring, ie; the standard box just eases up on the
throttle when it changes gear. This was disconcerting when you are hammering it. This behaviour is a thing of the past now.
During normal driving, the changes are not noticeable but when you accelerate and particularly between 3000-4000 rpm, the changes seem almost silky smooth.
Thanks again to Craig for the work. :worship:
I'd recommend this to anyone with a NM35/PM35.
Found this while I was shopping tonight, funnily enough after Craig and I had a conversation on people overcharging for parts: http://www.conceptzperformance.com/Cart/description.php?II=1198&Car_Type=G35&UID=20110915052013118.210.201.250
It MUST be better :nyaanyaa:
    • R32 pics Not sure if you can upload pics directly, but i've added them through an imgur link above.
    • There’s a possibility that Infinity G35x front hubs may be compatible, but it depends on the exact fitment. Sometimes, parts like hub and bearing assemblies from different models can work if the bolt patterns, bearing sizes, and axle specifications match, but the G35x hubs typically have a different design. It's worth checking detailed specs (like the number of bolt holes, size of the axle shaft, and bearing diameter) to compare, as Rock Auto does list some parts that cross over across different models. If you're going for a pre-pressed hub and bearing unit, that could be a good option. These units are usually easier to install, as the bearing and hub come pre-assembled, but you’ll still need to verify fitment, especially the outer diameter of the hub and bearing dimensions.
    • Love the input man! Defo gonna check it out
    • 1994 Series 3 R32 GTR. Freshly built as the perfect weekender. Has many brand new Nissan OEM pieces (some you can no longer source). Last serviced (April 2024) at V Spec Performance, Melbourne, Australia. Feel free to DM me if any questions. Asking price: $190,000 AUD.  Engine RB26DETT Original 05U block Factory R32 crankshaft CP 86.5mm forged pistons Spool forged rods Factory cylinder head – rebuilt Factory valve train Factory camshafts Factory inlet manifold Factory throttle body Garrett dash -5 turbos Custom intercooler piping with Plazmaman clamps Plazamaman 100mm race intercooler Turbosmart BOV Tomei fuel rail 660cc injectors Goodridge 9000 series fuel lines with crimped fittings Stainless steel front pipes Tomei titanium exhaust with stainless steel cat converter Spit fire coils Powder coated rocket covers New Nissan coil pack emblem badge Fully repainted engine bay in Factory Black Refurbished ABS unit New Nissan brake master cylinder New Nissan brake lines New Nissan clutch master cylinder New Nissan washer bottles Custom catch can (powder coated with Goodridge lines) Steering rack rebuilt New Nissan power steering lines New Nissan AC lines A/C compressor refurbished AC condenser refurbished HPI radiator and new thermos fanes New radiator fans NOTE: All nuts, bolts, fixings new or zinc coated Driveline Factory 5 speed gear box rebuilt Xtreme twin plate clutch Stainless steel clutch line Rebuilt factory transfer case Custom one-piece tail shaft Rebuilt factory front diff Rebuilt factory rear diff Suspension HICAS deleted Bilstein dampers IKEYA formular front and rear arms and tie rod ends New bushes wherever possible Whiteline anti roll bars (underneath car only) Brakes Brembo F50 front callipers – 4 piston AP racing 380*32 front rotors, J Hook design Custom floating hat and calliper mounts Brembo 4 piston rear callipers PFC pads Stainless steel braided brake lines Body New Factory Black paint job Ceramic coated exterior panels New Nissan aluminium bonnet (super rare) New Nissan headlights (super rare) New Nissan indicators New Nissan front bar New Nissan front lower lip New Nissan head light and bonnet seals New Nissan windscreen cowling New Nissan wiper arms and wiper blades New aftermarket windscreen New Nissan windscreen seal New Nissan front doors window surrounds and seals New Nissan rear quarter windows (must replace for proper paint job) New Nissan rear window surrounds and seals New Nissan side skirts New Nissan boot badges New Nismo rear bonnet lip New Nissan guard liners Interior New Nissan lens cover over cluster New Nissan gear boot shift New Nissan gear knob New Nismo steering wheel New Nismo floor mats New Billet Handbrake lever New Nissan OEM pocket facia to replace radio Underbody Original stone guard removed and new stone guard coating applied Powder coated front and rear cross members Fuel lines painted to match factory colours Fuel tank removed, cleaned, repainted and refitted All nuts and fixings cleaned, repaired and zinc plated Wheels Rays/Volk racing TE37 18 x 10.5 + 15 in Bronze Yokahama A050 265 x 35 x 18
