hey guys posting on behalf of a mate so dont ask me for further info cos i dont kno, call the number i provide please
r33 gtr v spec box (80,000)kms $950
n1 turbo and 2 stainless dump pipes with exhaust manifold off 33 v spec $650
rb26 bottom end no sump, cp pistons, argo rods, nos rated rings, acl race series bearings, jun collar, brand new n1 oil pump with after market billet gears. motor has been balanced but changed to a 3.0 litre bottom end $4500
also has a 33 gtr he is wrecking out and lots of various parts avail so just call for details. i know he has perfect rear quarters, doors, centre trio gauge pod and various other good condition interior and exterior pieces avail
contact roy on 0424775829
i will check back daily to answer any questions i can but as i said please just contact the seller
Edited by NUT515
https://www.sau.com.au/forums/topic/373141-garage-sale/
all items are located in toowoomba qld. postage can be arranged at buyers expense.
also avail are a
set of 18 inch 3 piece roh modena wheels with rubber for $2000
set of 18 inch xp racing wheels with rubber $1000
dont know offsets and widths will try and get pics for them
https://www.sau.com.au/forums/topic/373141-garage-sale/#findComment-5955851
u chasing the front or rear guards mate?? it is midnight purple in colour.
sorry mate no exhaust cam as the motor is already sold.
i will find out bout the plastic inner guards, the car did cop a hit in the front so unsure of the condition of the liners
https://www.sau.com.au/forums/topic/373141-garage-sale/#findComment-5973732
thanx so much.. if there still in shape and not cut or anyhing , should be good.. thanx :)
https://www.sau.com.au/forums/topic/373141-garage-sale/#findComment-5975844
  • 10 months later...
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
