I was advised at one point to go find a local spring works (yellow pages) and they can make up anything you need ;)
was all too hard for me though
I was going to suggest that. Pretty much any spring that fits in there without falling over will do the trick anyway. And shimming them as already suggested will raise the pressure somewhat. Its all very easy.
Lol at lending ya car. I sure as hell wouldn't. I only let the missus take it anywhere.
I don't have a problem with mates driving my car, after all it's just a car. I often take my car to the skidpan where I let my mates have a go, it's something I think everyone who has an appreciation of cars should experience. But perhaps not at 400rwhp when they are used to driving beaten up Honda Civics, etc.
On the skid pan wouldn't be as bad cos you got your eye on it and also they aren't on the road with the opportunity to see how fast it goes or something stupid.
I loaned my skyline once and it came back with 7800 rpm on the hand controller and 170 kph. Plus the clutch stunk and I'm sure that's why it is slipping now. I loaned my commodore once as well and the guy got a speeding ticket and ripped the front bumper off on a kerb and blew a hole in the radiator which only happened at the time from revving the crap out of it.
You say its just a car but for me it is months of work and saving. If someone really appreciates a car they can work their arse off and save their money and get their own like most people do. But hey that's just me biggrin.gif
Yeh I don't just approach people on the street and hand them the keys lol :P I have a close group of friends, would trust them with far more than my car. They could easily get their own, but it's just not something they want. They enjoy driving it but they see the headaches I have with it sometimes (like the hot start issue) and it just isn't for them. Or they have a different taste in cars, eg my mate has a '78 Escort that he is building. We all have our own tastes, mine just happens to be set up for track work :P
Edited by Hanaldo
I hear ya. It's good to have mates you can trust like that. I've only been in perth for ten months so I don't know many people here. On topic now, why don't you try putting some big washers under your 7 psi spring and seeing how much it raises the boost by. If your car isn't set up for the gate yet we can try it out on my car sometime.
on this topic, does anyone know if the tomei 270 8.8mm lift cams would be okay for a stock rb25 hydro and stock springs?
This is an external wastegate thread, were discussing spring pressure in the gate and target boost.
Your probably looking for another thread, however I think the duration has nothing to do with how well it will work as its more the lift. IMHO the stock springs are shit to begin with, I would ditch them in a mad hurry.
or better yet lets just ditch the whole engine for one with a toyota badge...right?
Hanaldo: speaking with Sean from Allstar I was told to downgrade my spring, had a 7 and 14 in my 48 progate to just the 14 and use my avcr to run what ever high boost, aiming for 25psi, reason being the ecu can pull boost out if something is overheating or going wrong,
I was under the impression of getting the spring pressure as close to the target boost as possible too,
it depends on your setup, with internal gate and an actuator getting one close to your target boost is more important than with external gate as with external you can use both ports to hold the gate shut until a few psi before your target boost.
i say see how you go with your current spring and if its not enough you can always change it later.
ive got some Turbosmart wastegate springs laying around is interested in them, one has yellow paint (largest), one has red (medium) and another i think has orange (small) paint sprayed on it
im not sure what psi they are, they have been sitting in my room for about 4 years and have some surface rust on them but nothing major
Haha well those sound like they are from a Pro-Gate or Power-Gate, so they wouldn't fit my application. The red one might fit the Comp-Gate, is it red and brown or red and black? In case you're interested, the yellow one would be a 14psi middle spring, and the red one would be either an 11psi middle spring or a 12psi outer spring. If the red one is smaller than the yellow one then it's probably from a gate like mine.
I saw a spring at work today which looks like it would fit. The bloke said I can have it soon when he replaces it with a new one soon. It is very hard to compress by hand. I succeeded in compressing it about 3mm. I'm keen to try it. Just by the feel of it I'd say it is good for 20 psi or more by itself
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
