Hi,
I'm changing my wheel size, and have a set of 4 Michelin 27/68R18 Slicks. The slicks have lots of tread left (see pics) and have had two treatments of octopus grip to keep the rubber soft.
I'm chasing $500 for the set of 4 firm. I paid way more than that for them and I haven't used them.
Located in West Sydney
Craig
0424854025
It depends on your set up. I run standard blow of valves and they touch when you turn lock to lock. My car is pretty low, and it kisses the top of the suspension when you bounce. I only trial fitted them. Lots of guyd on the UK GTR forums run this size, I just cant be bothered raising it and changing the bov's
These are too tall for a 33 gtr aren't they?
Hey mate,
How old are the slicks?
Looks like they will be good for the LM
Where are you located, I live in Wollongong So not far away and can pck up.
Cheers
Matt
Hi mate, I'm not sure on their age. The Octopus grip softens them back up quite a lot. A friend used it too on his slicks and the grip increase was quite noticable.
I'm at glenmore park, which is just before Penrith, along the northern road (camden valley way).
Hey mate,
Cheers
Matt
What size wheels do you need?
Big ones.
27 / 68 – 18
First Number indicates approximate tread width in centimeters
Second Number indicates overall diameter in centimeters
Third Number indicates rim diameter in inches
//EXAMPLE
Tire has 27 cm wide tread, is 68 cm in diameter, and uses an 18 inch wheel
Diameter in inches = 68 / 2.54 = 26.8 inches
Approximate* tread width in inches = 27 / 2.54 = 10.6 inches
So, it is similar in size to a 27 x 10.5 – 18 tire in common North American designation
Google is still free.
http://www.michelinman.com/media/en-US/pdf/motorsports/Michelin_Race_Tire_Catalog.pdf
FWIW a 245/40/18 tyre is 65cm diameter.
Edited by simpletool
Hi, the catalogue states a 18x10.5 to 18x12 wheel is required. I know from experience, and any slick retailer will tell you, they will fit anything from 18x9.5 to 18x12. The 9.5 and 10 inch rims require a psi or two more pressure to stiffen the side wall. I have seen a few guys at csca doing this. I had these fitted to 18x10 rims perfectly.
  • 3 weeks later...
Still available! I'm back from overseas. Someone must want some near new slicks? I slashed 6 seconds off my Wakefield time with smaller slicks...
    • 1. Factory knock sensors for now, honestly the RB26 OEM knock sensors seem ok as they're flat response instead of resonant type but they appear to be internally grounded to the block. If I do replace the sensor it would just be to get ones that are not internally grounded so a differential input can be used to reject common mode noise. Definitely plan on fixing this as a part of the tuning process. 2. Never deliberately induced knock, though I guess I could try that experiment if I really wanted to. 3. All of this is basically on a stock engine + ECU, only modification is HKS GTIII-SS turbos and a Nismo plenum. Currently I run it with the wastegate solenoid unplugged so it won't try to raise boost past wastegate pressure.
    • After being peer-pressured into paying $100 for the MW remakes, got BO6 on XBox Game Pass. I think that's worth it.
    • That's a given!  Bit hard to powdercoat it properly without removing them! 😁
    • No detail on compressor or turbine sizes, which doesn't help with housing size selection with that kit. However, from SR20DET mucking about and money torching perspective, a GTX2860R Gen 2 w/ 0.64 (46mm inducer) will do ~260kW on E85 about 1.5bar of boost. All in before 3000pm, which cause a gearbox to shatter. Now imagine the same turbo, on a modern motor with an extra 0.5L of displacement, and heaps of cam timing adjustability (not an on/off affair like the Nissan shit boxes). If this was my car (which I would never own or consider buying, ever!), I would go for a nice twin scroll setup, and a G30-660. Gates plumbed back, no silly shit. Lean on the cam timing, big displacement to create a flat-ish torque curve.
