Rifling would be a waste if time and great expense, because you aren't realizing that it's for the projectile, not the gas.
Also, using boost pressure for water methanol is another waste of time. You need the wmi at low levels of boost when the car is under the most load. Without much pressure, you aren't going to atomise the the mix anywhere near enough, so it's not goin to work.
My system worked well at 150 psi, the mix was like steam. Anything under 50psi and it dribbled, like the shit your posting.
Common sense, there is a lack of it these days. People need to realize these ideas would be utilised by BMW, Ferrari, Nissan, etc if they were so great. Why? Because they have millions for R&D, and much smarter people than a few kids on a forum.
I don't see the need to be so harsh... You blindly discourage innovation. It was an idea, even if it doesn't work, it was someone trying to think of a method to improve.
Explain why it wouldn't work, pat him on the back for thinking. Don't shoot him down for both.
Thanks man, like i posted that im no engineer and dont understand gas dynamics. I just had an idea and wanted to learn from the pros.
I saw Mafias post and wondered how he treats people around him in everyday life who ask a question.
Now GTSboy, im impressed with but i wont pretend to understand everything he wrote but i got some of it. Thanks man
Slightly off topic. (sorry) I'm not sure if i'm just a bit slow lol, (actually i probably am), but something i didn't know up until a couple of years ago after seeing some engine dyno results, was that exhaust manifold and port sizes should not be port matched. I've seen alot of people taking to their exhaust ports and cast manifolds with die grinders trying to get a perfect port-gasket-runner diameter match, when infact there should be a 'slight' step in diameter with the exhaust port of the head being smaller than the runner diameter to help stop a bit of exhaust gas reversion back to the cylinder.
Edit. Not sure if this particularly applies to forced induction, as they were only atmo engines i saw results for. I guess with the pressure differential between inlet and exhaust on a turbo it wouldnt make a huge difference.
Edited by _x_FiReStOrM_x_
Heya GTSBoy!
Good to see someone who actually knows what the fark they are talking about.
Just to add, 'rifling' would be best designed for a small range in velocity. Low speed 'rifling' would disturb laminar flow at high velocity and high speed 'rifling' at lower velocities would be much less effective.
GTSBoy, what do you do?
I learnt most of my aero knowledge through a good mate who was an aerodynamicist at Williams F1 for a while.
PM me if you're keen for a chat about nerd stuff!
Mark :)
And? Look inside most OEM plenums and you will find all sorts of interesting lumps and bumps and grooves designed to even the distribution to the cylinders. Ever wonder how the hell a conventional RB20 or 25 inlet manifold manages to get pretty eve distribution to all 6 even though the TB is directly opposite #s 3&4? Same reasons.
There is no way that a spiral groove on the inside of a plenum is going to get the whole mass of gas rotating in the <1 complete turn available from the TB to #6. But it may well be able to influence the shape of the flow to make it spread out a bit better (and not purely because it's spiralled.....that may just have been a crackbrained ida that some Nissan engineer tried and found out that it did what they wanted).
And?
I was just pointing out that Nissan HAS done something like that and they wouldn't have gone to the effort of it without good reason.
I'm just a designer, not an engineer but as a designer I have to take into account HOW things are made and you certainly wouldn't make your casting any more complicated that it needed to be.
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
