Rifling would be a waste if time and great expense, because you aren't realizing that it's for the projectile, not the gas.
Also, using boost pressure for water methanol is another waste of time. You need the wmi at low levels of boost when the car is under the most load. Without much pressure, you aren't going to atomise the the mix anywhere near enough, so it's not goin to work.
My system worked well at 150 psi, the mix was like steam. Anything under 50psi and it dribbled, like the shit your posting.
Common sense, there is a lack of it these days. People need to realize these ideas would be utilised by BMW, Ferrari, Nissan, etc if they were so great. Why? Because they have millions for R&D, and much smarter people than a few kids on a forum.
I don't see the need to be so harsh... You blindly discourage innovation. It was an idea, even if it doesn't work, it was someone trying to think of a method to improve.
Explain why it wouldn't work, pat him on the back for thinking. Don't shoot him down for both.
Thanks man, like i posted that im no engineer and dont understand gas dynamics. I just had an idea and wanted to learn from the pros.
I saw Mafias post and wondered how he treats people around him in everyday life who ask a question.
Now GTSboy, im impressed with but i wont pretend to understand everything he wrote but i got some of it. Thanks man
Slightly off topic. (sorry) I'm not sure if i'm just a bit slow lol, (actually i probably am), but something i didn't know up until a couple of years ago after seeing some engine dyno results, was that exhaust manifold and port sizes should not be port matched. I've seen alot of people taking to their exhaust ports and cast manifolds with die grinders trying to get a perfect port-gasket-runner diameter match, when infact there should be a 'slight' step in diameter with the exhaust port of the head being smaller than the runner diameter to help stop a bit of exhaust gas reversion back to the cylinder.
Edit. Not sure if this particularly applies to forced induction, as they were only atmo engines i saw results for. I guess with the pressure differential between inlet and exhaust on a turbo it wouldnt make a huge difference.
Edited by _x_FiReStOrM_x_
Heya GTSBoy!
Good to see someone who actually knows what the fark they are talking about.
Just to add, 'rifling' would be best designed for a small range in velocity. Low speed 'rifling' would disturb laminar flow at high velocity and high speed 'rifling' at lower velocities would be much less effective.
GTSBoy, what do you do?
I learnt most of my aero knowledge through a good mate who was an aerodynamicist at Williams F1 for a while.
PM me if you're keen for a chat about nerd stuff!
Mark :)
And? Look inside most OEM plenums and you will find all sorts of interesting lumps and bumps and grooves designed to even the distribution to the cylinders. Ever wonder how the hell a conventional RB20 or 25 inlet manifold manages to get pretty eve distribution to all 6 even though the TB is directly opposite #s 3&4? Same reasons.
There is no way that a spiral groove on the inside of a plenum is going to get the whole mass of gas rotating in the <1 complete turn available from the TB to #6. But it may well be able to influence the shape of the flow to make it spread out a bit better (and not purely because it's spiralled.....that may just have been a crackbrained ida that some Nissan engineer tried and found out that it did what they wanted).
And?
I was just pointing out that Nissan HAS done something like that and they wouldn't have gone to the effort of it without good reason.
I'm just a designer, not an engineer but as a designer I have to take into account HOW things are made and you certainly wouldn't make your casting any more complicated that it needed to be.
    • Yeah its bad eh. Ey! Watch your mouth. Yep, spot on. The rear's are always gone too though from brake checking. I had them perilously close to a tree that we had taken down. I think the tree peeps may have taken it. Either for a trophy, or accidentally.
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.         As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.      I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.    Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.            BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
